Results 1 to 3 of 3
Thread: help needed
    Regular Member justin32's Avatar
    Aug 2011
    Basingstoke
    Vehicle : Vectra c SRI Facelift
    Trim : SRI
    Engine : 1.9 CDTI 150
    Default help needed
    A few days ago i cleaned my EGR valve(propper clean inc taking it apart) and now when i accelorate past 2k theres a high pitched noise which sounds a bit like breaks squealing or high pitched air leak,it will do it all the time i accelorate untill i ease off.If i rev the car when its stationary it doesnt do it.
    Also when i turn the engine off the whole car sudders really bad.
    Funny thing is that the car is running better than ever after the EGR clean so cant understand whats going on?
    Any help would be great
    Regular Member Toe-side's Avatar
    Dec 2011
    Northumberland
    Are you sure you remade all the gasket / joints correctly when reassembling? It might be worth a check. Does it sound like whistling?
    Aug 2011
    Basingstoke
    Trim : SRI
    Quote Originally Posted by Toe-side View Post
    Yeah i think the gaskets when on ok,although i spose it wouldnt hurt to double check.
    Sometimes it sounds to me like a break squealing noise but with the passenger window open it sounds like a very high pitched whistle.
    Its not turbo related as thats sounds like normal and is working fine and no smoke
  1. Amp help needed
    By minimission83 in forum Electrical & ICE (including SatNav)
    Last Post: 5th March 2012, 22:17
  2. help needed
    By sebadee in forum Engine & Drivetrain
    Last Post: 21st January 2011, 19:57
  3. Help needed!!
    By seannygoat in forum Electrical & ICE (including SatNav)
    Last Post: 26th December 2010, 17:23
  4. Help Needed
    By Andie-100 in forum Engine & Drivetrain
    Last Post: 19th December 2010, 21:51
  5. How To Needed........
    By spennny in forum The 'Off Topic' room
    Last Post: 17th July 2009, 14:17
