Results 1 to 10 of 15
Thread: Double din problem
    Nov 2009
    manchester
    Exclamation Double din problem
    Help,i bought a jvc double din and a aerial connector and a quadlock to iso connector, when i connect it all up i get nothing!!, i have swapped the red snd yellow over and themost i getfrom the unit is c.d sound or the display will light up if i press it, no sound, no nothing. Not sure if my car is half,fullcan, it has the two wheelson the steeringwheel. Please somebody stop me from throwing it at the wall.
    Full Member Robsey's Avatar
    North East Cheshire
    11 Post(s)
    Trim : Energy
    Mileage : 131,000
    Scrollers on the steering wheel means full CAN
    That is why you have Quadlock and Fakra connectors.
    Half CAN vehicles have buttons only on the wheel, and ISO / DIN connectors.
    Right then -
    The JVC loom yellow should go to your quadlock red wire - pin 15 -battery live
    The JVC loom red should go to the black wire on the cigarette lighter / charger socket. - Ignition live for radio memory and ignition logic etc.
    The lighting for the JVC unit should be wired up to the grey/yellow wire of the cigarette lighter / charger socket.
    or you could use the spare socket tucked inside the trim panelling below the hand-brake, if you do not have a rear lighter / charger socket.
    Nov 2009
    manchester
    Ok thank you guess i know what i am doing in the morning then
    North East Cheshire
    11 Post(s)
    Trim : Energy
    Mileage : 131,000
    Just a slight clarification -
    Cigarette lighter will have 3 wires
    Grey/yellow - lighting - ring illumination (this may be separate from the main connector)
    Black - ignition live
    Brown - chassis earth / ground
    The charger socket will just have ignition live - black,
    and the ground - brown
    with a separte two pin connector tucked down by the hand-brake - brown (earth) and grey/yellow (illumination)..
    Nov 2009
    manchester
    Whereabouts in manchester you from Robsey
    North East Cheshire
    11 Post(s)
    Trim : Energy
    Mileage : 131,000
    Near Ashton-Under-Lyne - the east side of Manchester.
    Nov 2009
    manchester
    So where would i wire up the lighting for the head unit if mine is a charger
    Nov 2009
    manchester
    Near airport me
    North East Cheshire
    11 Post(s)
    Trim : Energy
    Mileage : 131,000
    edited original post to add detail
    North East Cheshire
    11 Post(s)
    Trim : Energy
    Mileage : 131,000
    Quote Originally Posted by davehindley View Post
    Near airport me
    I regularly work on that side of Manchester, however you are only about 15 miles by motorway from me.. M60 & M67.
  1. Wiper Electrical Problem? (Not sticking or cold weather problem)
  2. help double din kit
    By marc vectra sri in forum Electrical & ICE (including SatNav)
    Last Post: 21st September 2011, 18:35
  3. Double Din
    By ukmayhem in forum Electrical & ICE (including SatNav)
    Last Post: 3rd June 2009, 12:40
  4. Double Din
    By Mick B in forum Vectra C / Signum Car Chat
    Last Post: 1st April 2009, 19:18
  5. Problem...? Vectra SXI...problem with starting after filling with fuel?
