Results 1 to 3 of 3
Thread: Steering angle sensor
    Oct 2011
    larkhall
    confused Steering angle sensor
    Hi Guys
    First post
    Took my vectra jan 2007 1.9 cdti (120) with esp in to local power steering company told I needed a new pump after checking they came back with seized steering nuckle on column £140 + vat . Guy told me that my sas was needing replaced (light on) .He cant find it on the rack and says its somewhere on the column also mentioned its a rare p/steering rack I have . He phoned dealer who said £98 + vat and it's round in shape.
    Any idea's where its located and okay to do DIY got a bit on mechanical knowledge .
    Cheers Greg
    Full Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    Yes, its your steering colum module that needs to be replaced.
    its the bit where you also control your wipers, indicator ect. (need to remove steering wheel to replace it)
    Edit: what i originally wrote is wrong, sorry..
    The pump is either electric, and is on the colum, but the part you are looking for is probaly infront of your drivers side wheel, you will need to remove the bumper to get to it.
    Quote Originally Posted by Gregiboy View Post
    Sounds like they aren't very experienced with the Vectra C
    I'd go elsewhere, if they can't diagnose that correctly, what are they going to be like when they actually perform the repair...
    They should know what the pump looks like and found it within a few minutes (or even phoned up a local dealership parts department to check)
  1. Steering angle sensor
    By RichM in forum Electrical & ICE (including SatNav)
    Last Post: 11th November 2012, 20:22
  2. Steering angle sensor
    By 1979john in forum Troubleshooting
    Last Post: 16th August 2011, 20:24
  3. steering angle sensor?
    By robwilson69 in forum Suspension, Wheels & Brakes
    Last Post: 23rd December 2009, 12:40
  4. Steering Angle Sensor
    By r.bailey63 in forum Suspension, Wheels & Brakes
    Last Post: 25th July 2009, 14:48
  5. Steering Angle Sensor
    By chanito in forum Electrical & ICE (including SatNav)
    Last Post: 1st August 2007, 18:12
I need Vauxhall Zafira 1.9 diesel steering angle sensor
vauxhall vectra 2006 angle sensor
esp steering angle sensor vectra c
vauxhall vectra steering wheel angle sensor removal
steering rack sensor for opel vectra c
