Thread: vectra c 1.9 cdti 120 diesel judder at around 2000 revs
    Bristol
    Default vectra c 1.9 cdti 120 diesel judder at around 2000 revs
    Hi all,
    I have a problem where at around 2000 revs the car judders & jerks & you can hear a strange noise. Sometimes also happens if you are accelerating and then eay off on the accelerating.
    I've only just had the EGR valve changed a few day ago & didn't have any sort of problem like this before.
    Could it be related to injector 3 as I have read on similar threads?
    Any help or insight gratefully received as its driving me mad at the moment.
    Gary
    morecambe
    42 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    injectors possible have u donr the revised 3rd injector mod
    Bristol
    Thanks for quick reply. I've not touched anything yet as complete novice when it comes to cars etc. is it easy to do?
    morecambe
    42 Post(s)
    Vehicle : vectra
    Trim : vxr
    ye get the kit from vx and if ya can use a solderin iron its easy also worth checking the boost pipes aswell
    Bristol
    Had a quick look & the cover on the 3rd injector is much newer than the other 3 so presume that it has had something done to it.
    Not sure what & where boost pipes,will google & find out.
    Ta.
    Bristol
    A bit of reading so I have disconnected the EGR valve & the juddering, jerking and whooshing disappeared. It is a new unit fitted on Friday so may be the software needs updating? Re-connected the EGR & same problem starts happening.'the spanner light also went off after r-connecting.
    So another visit the dealer again on Monday.
    Bristol
    South Central England
    9 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Might be a faulty valve they put in, these things happen. The only other thing I can think of is the MAF as that is used to detect EGR function.
    Bristol
    Final update, took back to the dealer & they did the software update to the ecu and car no longer judders etc, so all resolved.
  1. Black exhaust smoke on high revs, EGR light on, rough idles - 1.9 cdti 150 diesel
    By bananas in forum Vectra C / Signum Troubleshooting
    Last Post: 5th September 2012, 13:25
  2. Replies: 43
    Last Post: 8th June 2011, 21:03
  3. Jumpy at 2000 revs
    By Planner in forum Engine & Drivetrain
    Last Post: 10th June 2010, 17:41
  4. smoke at 2000 revs
    By vectra-c1000 in forum Vectra C / Signum Car Chat
    Last Post: 24th April 2008, 18:09
  5. Engine Judder 2.0 DTI at 2000 revs
    By cp123 in forum Engine & Drivetrain
    Last Post: 16th January 2008, 17:38
vectra c 1.9 juddering at low revs
vectra c black smoke and engine hiss car judders
vectra c 1.9 cdti juddering at low revs
vectra 1.9 120 juddering when accelerating
