Thread: Second Rear Foglight loom
    Regular Member Keif's Avatar
    In the Garage
    Default Second Rear Foglight loom
    As you're aware the Vectra C and Signum only has one rear fog light. (offside). The loom is missing for the nearside.
    The fix is relatively easy, an additional wire/pin needs adding between the Black/Blue wire (for the rear fog) and the multi plug on the nearside.
    I have available 6 short lengths of loom with the correct connector.
    The connector just pushes into the spare hole in the nearside multiplug. Then a simple piece of soldering (striping a small section of Black/Blue cable and soldering the extra loom and insulating). In most cases the nearside rear fog light already has a bulb in place.
    (Please note the brown wire in the picture will be replaced with a length of wire the correct gauge)
    A simple upgrade that will make you seen better in bad weather.
    These are £5 each. (delivered)
    These will be posted out recorded delivery only (£2 delivery).
    However if you live locally to me (Jtn26 M1) I'll quite happily fit one for you. (for £2)
    In the Garage
    3 Sold. Thank You
    2 Provisionally Sold
    In the Garage
    After looking at fitting one of these to Bishbash's estate, I didn't realise that the estate loom is different to the rest of the Vectra/Signum family, and this extra loom will not fit into the smaller connector.
    Apologies again to Bishbash, and PM sent to others who this relates too.
    In the Garage
    5 gone.....
    Last one still up for grabs.
  1. Front foglight wiring loom.....
    By SlowCoach in forum Electrical & ICE (including SatNav)
    Last Post: 4th October 2012, 18:32
  2. rear foglight
    By winnie2457 in forum Electrical & ICE (including SatNav)
    Last Post: 22nd February 2010, 15:40
  3. Replies: 13
    Last Post: 25th January 2010, 18:01
  4. Foglight, 17"alloy c/w tyre, and new rear hub
    By GARY3306 in forum Parts for sale
    Last Post: 17th August 2009, 21:07
  5. rear foglight
    By decks in forum Vectra C / Signum Car Chat
    Last Post: 18th July 2008, 09:31
