Results 1 to 3 of 3
Thread: H/B Antenna Base seal change - Shark Fin ?
    Regular Member Led's Avatar
    Kings Langley
    Cool H/B Antenna Base seal change - Shark Fin ?
    The rubber seal on mine has split and after a visit to the local dealers I found out that you cannot buy just the seal - you have to buy a complete base at £42.81 + vat
    Has anyone changed there unit for a Shark Fin unit ?
    If so what oen did you use ?
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 65500
    Just nip to the scrappys and have a look for one with a good seal, the seals on the ones on Vec B's fit the vec c base. When refitting put some Vaseline around the roof and the seal, this should help seal it and may keep the rubber from hardening too.
    East Midlands
    Quote Originally Posted by Led View Post
    This should fit your aerial mate, if its not the sat nav base..
    Cheapest option as well.Just seal round it like lots have done with clear silicone sealant.
    http://www.ebay.co.uk/itm/4001341372...#ht_532wt_1102
  1. Aerial Base seal replacement
    Last Post: 27th December 2011, 10:36
  2. Aerial base seal gone
    By paul wingnut in forum Electrical & ICE (including SatNav)
    Last Post: 10th December 2011, 18:06
  3. Replace original antenna for an amplified shark tail type?
    By cornel18 in forum Electrical & ICE (including SatNav)
    Last Post: 26th April 2011, 16:57
vectra c roof aerial
how to replace vectra c aerial
vauxhall insignia shark fin aerial seal
vectra c roof aerial seal
vauxhall insignia sharkfin aerial seal
how do you change the roof aerial on a vauxhall insignia for a shark fin aerial
