Results 1 to 10 of 18
Thread: Display
    Feb 2011
    BEDFORDSHIRE
    Default Display
    Hi
    I have a 2006 CDTi SRi and the display fan has a permanent clicking noise when it kicks in.
    It sounds like the fan blade is hitting a wire or fouling something. It works okay it's just annoying.
    Has anyone had experience of this or can tell me how to get the display out to investigate?
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    not sure what you mean about display fan fella
    Feb 2011
    BEDFORDSHIRE
    Default Display
    Sorry, I mean the central sat nav colour LED screen.
    Are you VXR Enough
    13 Post(s)
    the colour screen has a fault?
    Regular Member cossie's Avatar
    MANCHESTER
    I thought you were talking about the heater fan. If you are - The fan is behind the glove box - I dont think (although I stand to be corrected) you need to take the display/vents out - just remove the glove box and the heater blower housing is located under there in the passenger footwell.
    If you do need to remove the display and centre vents, the trim panel (colour and style dependant on trim level) is easily pulled off (make sure you do it evenly so as not to snap it) revealing four torx screws holding the whole centre panel in - here is a pic with it all removed if it assists you
    Feb 2011
    BEDFORDSHIRE
    Thanks for the info.
    It is the display between the two central vents. I think this is where the noise is coming from (or possibly the radio. It's not the heater fan).
    The noise/fan is only heard on hot days and only comes on after a while i.e. when the display has obviously got hotter.
    Are you VXR Enough
    13 Post(s)
    the display dosnt have a fan fella. the head unit i dont think has one either maybe its the cd drives in the head unit?
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    Spinds more like the fan in your radio that have problems
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    There's no fan on the screen fella. It's possible if you've fitted an aftermarket radio THAT has a fan in it (I've seen a few that do), but none of the standard ones do, it could be the CD mechanism in the radio got a tooth gone on a drive cog.
    It's could also be the recirc cogs in the main fan unit or something.
    Alternatively you've got an electrical short somewhere that's arcing (can sound the same sort of noise) in which case I'd rip it all out quick and check it because that could start a fire if it's the case.
    Feb 2011
    BEDFORDSHIRE
    It's definitely some sort of fan. When it cuts out you can hear the fan slowing down.
    The car has the standard head unit. So perhaps it's the radio. I'll have to visit halfords and get the kit pull it out.
  1. Replacing Board Info Display (BID) with Color Info display (CID)
    By grigs1 in forum Electrical & ICE (including SatNav)
    Last Post: 11th April 2012, 22:13
  2. mp3 on display
    By marc vectra sri in forum Electrical & ICE (including SatNav)
    Last Post: 27th August 2011, 14:54
  3. PS3 display
    By @ndy-e in forum Games Room
    Last Post: 27th December 2010, 08:21
  4. temp display on radio display
    By MRunMotorsport in forum Electrical & ICE (including SatNav)
    Last Post: 19th April 2010, 15:55
  5. LED DIsplay
    By dcraigen in forum Vectra C / Signum Car Chat
    Last Post: 18th September 2008, 10:16
