Results 1 to 10 of 13
Thread: VECTRA C SRI Front Bumper
    Mar 2012
    Cheshire
    Default VECTRA C SRI Front Bumper
    Hello this is my first post on the forum.
    I recently bought my vectra C 1.9cdti 150 and have noticed that the front bumper is not sitting flush just below the headlight (see Pictured), I have tried removing the front bumper but there seems to be nothing for it to clip into nor I can see which part I would even need to order for me to get this sorted.
    If anyone here knows which part I would need to order or a fix could you please reply.
    Eddie
    Regular Member Gubmint Agent's Avatar
    Feb 2011
    Feels a lot like Kathmandu.
    Trim : Sri
    Engine : 2.2 Direct
    Mine is similar but not quite so pronounced. Haven't done anything about mine though. You could try loosening off the clips/screws in the front of the wheel arch (as if you were going to remove the bumper) then tightening them up as someone else pushes the bumper under the headlight back in? D/K if that would work but..?
    Regular Member Dippy-Vx-line Red's Avatar
    Earlston (Scottish Borders)
    This must be a common thing as mine is the same...
    Full Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    you probably need a new one of these as the existing one is fubar from a previous bump.. They are held on by rivets, so drill out the old rivets buy a rivet gun kit from halfrauds and your done.. cheap and easy fix really.. Thats providing your bumper still has the bits on it that clip into this bumper guide..
    this is a right hand one apparently..
    http://www.ebay.co.uk/itm/VECTRA-C-S...item3f136fbcb0
    lefthand side apparently
    http://www.ebay.co.uk/itm/VECTRA-C-S...item41624cb927
    Regular Member pipamish's Avatar
    wolverhampton
    Trim : Sri
    Engine : 2.0 turbo
    I will have one up for sale shortly black aswell
    morecambe
    35 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    drill the rivets out take it off and use some extra clips in the wheel lining and at the bottom works a treat on hairys car when i face lifted it
    Mar 2012
    Cheshire
    Thanks guys Im going to go and have the bumper off and check if it is the bumper or the bumper guide,
    Im not quite sure what you mean paulvectrac by what you said could you please explain it better.
    Mar 2012
    Cheshire
    Regular Member Mads's Avatar
    Ipswich,.UK
    mines similar to that on the right side too, must be common, let us know if it works, i may get one of them clips.
    Mar 2012
    Cheshire
    how much
  1. Signum front bumper (Vectra c pre-facelift sri bumper) rubber skirt
    By 2.2 DTI SRI in forum Vectra C / Signum Car Chat
    Last Post: 28th February 2012, 20:23
