Thread: No power from 1.9 cdti 150
    Jun 2011
    Ayrshire
    Default No power from 1.9 cdti 150
    Hello!
    Hoping someone can help here
    I drive a 2004 1.9 cdti 150 and there is no power at all through the rev range.
    When crawling around at 20/30mph you can hear the turbo spooling up but when u put your foot to the floor, its as if your pulling a trailer, the turbo just doesnt kick in.
    Also when booting it, you get to maybe 65mph and then the EML light comes on and the car goes into limp home mode
    Any suggestions appreciated bcos im not really mechanically minded.
    Would an stuck open or closed EGR valve cause this prob?
    Regular Member Dane-10's Avatar
    Feb 2012
    Sheffield
    Sounds like permanent limp mode to me.
    Would be worth getting the codes read though, that wouldpretty much say what the issue was. Mine recently did it on swirl bar actuator. Could also be EGR as you say. Whip it off, clean it, check it if all looks good slap it back on and see if there is a change.
    Nov 2011
    Cheshire
    Vehicle : 1.9CDTi(120)SRi
    Engine : 1.9DT
    Mileage : 100k
    Check the usual, big boost pipe for splits, vac pipes for perished elbows or chafing damage, swirl bar, boost sensor and egr clean. Ideally get the codes read to find out what is putting the light on first.
    Events Manager & Moderator jon1.9cdti's Avatar
    Swanley , Kent
    125 Post(s)
    Vehicle : Sports Tourer
    Engine : A20DTH
    Year : 2010
    Mileage : 201000
    Quote Originally Posted by garetmcc79 View Post
    Hello!
    that is exactly the same symptoms as mine the day i purchased it, there was absolutely no power and no getting pushed into your seat etc, i also kept on getting eml if i tried to boot it in say 4th gear to get some sort of speed up,
    it turned out to be the vacuum/boost pipe, as a temporary fix i cut the pipe where it was split and used a length of hollow carbon fibre rod from a kite to rejoin
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Quote Originally Posted by jon1.8sri View Post
    sounds like this tbh. Get the silicon ones off of ebay or order some from the dealer.
    Swanley , Kent
    125 Post(s)
    Engine : A20DTH
    Year : 2010
    Mileage : 201000
    take a look at the following link in particular post 6 as it will show you the pipes that can cause these problems
    http://insignia-owners.com/forum/sho...d.php?t=109454
    Jun 2011
    Ayrshire
    Thanks for the help lads, i'll get the hoses changed ovr today and update u later
  1. 120 CDTI low on power
    By Boris in forum Engine & Drivetrain
    Last Post: 27th May 2012, 00:04
  2. little power 150 cdti
    By smokydiesel in forum Engine & Drivetrain
    Last Post: 26th May 2010, 19:13
  3. 3.0 cdti can you get more power from it??
    By m3ath3ad in forum Diesel Engine related
    Last Post: 6th May 2009, 23:09
  4. 150 Cdti down on power??
    By shrekster in forum Engine & Drivetrain
    Last Post: 7th December 2008, 00:19
  5. Another 1.9 cdti 150 with no power, low rpm
    By bigboss in forum Engine & Drivetrain
    Last Post: 10th April 2008, 16:58
