Results 1 to 10 of 14
Thread: What's the sensor for?
    Regular Member krazylegz's Avatar
    South Shields
    Default What's the sensor for?
    Just noticed a sensor on the windscreen, inside the interior mirror casing.
    Does anyone know what it's for, rain sensitive wipers or something?
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    Rain sensitive wipers.
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    There can be two sensors visible from outside just infront of your rear view mirror depending on the spec of the car. One is for auto wipers, one is for auto headlights.
    South Shields
    Ah right cheers lads, surprised mine has them on as it's only a sxi.
    Take it the wipers need to be in the first position for them to be on auto?
    Feb 2011
    Selby
    Also,
    Sensor on the back of the mirror housing itself (facing windscreen) is for the ambient lighting (on the bottom of the mirror housing).
    Sensor on the front of the mirror (facing the interior of the car) is for the auto-dimming function of the mirror.
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Quote Originally Posted by rich r View Post
    Also,
    Not quite .... the difference between the light levels detected by the front and rear facing sensors determines how much the self-dip function darkens.
    The down facing ambient light is the same intensity all the time when the vehicle lights are on.
    Ely, Cambridgeshire
    61 Post(s)
    Year : 2010
    Quote Originally Posted by Handyandy-UK View Post
    Ambient lighting only comes on in the dark if the lights are on, not just with vehicle lights. Try it, switch your headlights on in the daylight and your ambient lighting won't come on.
    Feb 2011
    Selby
    Indeed - it has to be dark for the ambient lighting to come on, so it must use the sensor in the mirror housing. If you put your headlights on when it's not dark (eg for fog/rain) it doesn't come on.
    11 Post(s)
    Indeed - it has to be dark for the ambient lighting to come on, so it must use the sensor in the mirror housing..
    It uses the sensor on the back of the mirror. Try covering it with tape and the little LED under the mirror will come on, regardless whether headlights are on or off.
    VIP-Member Z80's Avatar
    Apr 2008
    Noumea
    14 Post(s)
    Vehicle : Opel Vectra GTS
    Trim : Elegance
    Engine : 2.2 DTi 16V
    Mileage : 75 000
    Yes, that's the point.
    I was seriously thinking on adding an automatic headlights feature using that sensor.
    I just don't know if it would trigger faster enough, though.
    Th other alternative would have been to change the windscreen to a dual sensor model when it had to be replaced, but I just forgot to ask for it. Now I have to wait for someone breaking my windscreen again !
  1. Replies: 3
    Last Post: 13th August 2012, 22:25
  2. P0141-04 o2 sensor heater circuit open (bank 1 sensor 2)
    By Mark1892 in forum Engine & Drivetrain
    Last Post: 3rd August 2012, 09:19
  3. Fitting & Installation of ABS Harness & brake Help sensor sensor
    By Elahi_786 in forum Suspension, Wheels & Brakes
    Last Post: 17th April 2012, 20:46
