Thread: Tie rod and front wheel bearing!!!
    Regular Member scotty82's Avatar
    Mar 2012
    cannock
    Default Tie rod and front wheel bearing!!!
    Hi all im new to the vec-c front and having a couple of small problems
    Seems like i have a front passenger side wheel bearing gone and tie rod on the same side. When car is jacked you can feel slight play in the steering on passenger side, but drivers is fine and also driving between speeds of 40 and 50 you can hear like a humping noise from that side. If you turn to the right the noise gets louder, but if you turn to the left it goes Away.
    Is my theory right or is it something else??
    Also where would be the best place to buy these from and are the ones off fleabay any good????
    How easy are they to change???
    Thanks scott
    As with all suspension / steering parts, try to buy OE parts if you can afford it, and replace both sides on a like-for-like basis
    Where was the report on the parts from, and what was the status (play, worn, or failed)?
    Regular Member peadar's Avatar
    Aug 2007
    in the glens of Antrim N Ireland
    Vehicle : ELITE
    Trim : FULL LEATHER
    Engine : 1.9 CDTI 150 BHP
    Mileage : 87,000
    check your inner tie rod this can make the tyres drone and give the illusion that a wheel bearing is gone
    Regular Member sheepish's Avatar
    Yorkshire
    Check the How To's section, there's plenty for you there.
    Best bet is to take it to Halfords or who ever, let them work out what has failed, then do it yourself.
    If a bearing has gone, it's surprisingly hard to tell which side is making the noise.
    If your turning right your putting more pressure on the near side wheel so if the noise gets worse when turning right its more chance that the left hand bearing has gone not the right
    Sent from my iPhone using My thumb
    Forum Moderator FIL 4822's Avatar
    On a French Carp lake somewhere x
    6 Post(s)
    Vehicle : Insignia VX-line RED Tourer
    Trim : No, over weight!
    Engine : Flux Core Capacitor
    Year : 1 A.D
    Mileage : Rising
    Moved to "Troubleshooting" for ya Scott.
    Mar 2012
    cannock
    the report was done by myself, just checking my thoughts were right. Yes i will be getting genuine parts
    Quote Originally Posted by peadar View Post
    There is slight play in the passenger side tie rod, so i will be changing that at the same time!!
    Quote Originally Posted by sheepish View Post
    Last time one of my mates took a car to halfords, they told him it was the gearbox that was on the way out but ended up beind the wheel bearing
    Quote Originally Posted by marktaylor View Post
    My thoughts exactly was just checking though Looks like an expensive start to my relationship with it.
    Quote Originally Posted by FIL 4822 View Post
    Cheers phillip knew you were on here for a reason!!!
    Thanks for all your comments, Think im just going to get everything changed on the front for new parts. I think it was owned by a rally driver before me, Loads of mud in the arches and snapped xenon levelling bracket to the front lower arm
    As with all things, try what you can confirm has play or worn, and replace that (same advice as above with respect to steering / suspension and replace both side)
    If the problem / issue still exists then you know some further investigation needs to be done
    However, quite often one failed component takes others with it
    The easily worn parts are often identified first, before sourcing the actual reason
    wirral
    56 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Get genuine tie rod kit as as comes with new gaitirs clips and grease.
    Fairly easy to change in about hour an half
    wirral
    56 Post(s)
    Trim : Basic
    Engine : 1.6 16v
  1. front wheel bearing
    By paulb70 in forum Vectra C / Signum Car Chat
    Last Post: 23rd March 2011, 20:15
  2. Front wheel bearing/hub
    By daviek in forum Parts for sale
    Last Post: 9th April 2010, 16:55
