Results 1 to 10 of 25
Thread: Went for alignment - seized bolt!
    Hanging Heaton / Batley
    19 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 110k
    Default Went for alignment - seized bolt!
    Lower bolt on drivers size is seized... They didn't want to force it as they broke a vectra one yesterday... Nut comes off...
    Off to my mechanic now to see if can get it off, anyone foresee any issues. Really dont want it breaking so have to replace the lower arm.
    11 Post(s)
    I would have thought applying some heat will help shift it.
    19 Post(s)
    Mileage : 110k
    Mates busy I just rang him and he said same... Gonna take it in at 3.
    Now can't get car aligned till next week.
    19 Post(s)
    Mileage : 110k
    Double...
    Regular Member hairy31's Avatar
    Jun 2009
    bradford
    That's a ****ter mate ....blast it with penetrating fluid to give it some help
    Admin plasma's Avatar
    On the Forum
    325 Post(s)
    Engine : 150
    Mileage : 74000
    Check my thread out on it lol. Was totally stuck took a lot of grief to remove
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    19 Post(s)
    Mileage : 110k
    Quote Originally Posted by plasma View Post
    God... Better not come to that or I'll be well pee'd off.
    What methods had you tried previously?
    Regular Member Big Red's Avatar
    May 2011
    Dudley (Cramlington)
    Mate before you try heat you can get something called freeze and release its a loctite product that will do it use it on the machines and landys on opencast cos they constantly seize. Try heat as last resort
    HTH
    Stu
    19 Post(s)
    Mileage : 110k
    Quote Originally Posted by Big Red View Post
    HTH
    Stu
    Where do I get that from, is it a well know product? If so I have a couple of car places that may stock it...
    The nut comes off its just the ****** bolt...
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    Dean (plasma) had the same problem fella the bolt had welded itself in there and is still in the bush he showed me
  1. Seized brakes.
    By Kaz in forum Suspension, Wheels & Brakes
    Last Post: 20th February 2013, 17:35
  2. WOW!!! Dad in law bought seized vec c
    By SlowCoach in forum Vectra C / Signum Car Chat
    Last Post: 8th December 2012, 18:49
  3. trackrod end seized on
    By david106 in forum Suspension, Wheels & Brakes
    Last Post: 15th September 2012, 18:19
  4. seized caliper ?
    By conny in forum Suspension, Wheels & Brakes
    Last Post: 19th January 2011, 21:28
  5. bent seized bolt - bottom of rear shock
    By Caveman_nige in forum Suspension, Wheels & Brakes
    Last Post: 8th February 2010, 11:59
vectra c seized lower control arm bolts
