Thread: Vauxhall Signum - P0170 Error Code
    Reading
    Default Vauxhall Signum - P0170 Error Code
    Hello,
    I have a 55 plate Vauxhall Signum 2.8 V6 Turbo Elite.
    I've been suffering from a few symptoms:
    - Warning light on dash
    - Rough idle
    - Struggles to start after filling up. I have to press the accelerator a few times to get it to start.
    The car never struggles to start normally, but does everytime after filling up without fail.
    A friend plugged his Vauxhall diagnostics lead in and the car had one error code. This was P0170 - Fuel Trim System Too Rich - Bank 1. When the error is reset it immediatly comes back.
    I've noticed several different potential problems after searching the net however I wonder if any of you bright individuals could reduce this based on the symptoms I have.
    Andrew
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    Their is a purge valve on the back of the engine inlet manifold that normaly is the cause for non start.
    morecambe
    35 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    It's either the maf has gone mate or a lamba sensor thats what I would say
    Reading
    Matt/Paul, thanks for your suggestions.
    Anyone else want to comment?
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    I guess you may have seen this already? http://www.obd-codes.com/p0170
    Then read up on "testing MAF", some vids on Youtube.
    Full Member
    Mar 2007
    Finland
    Worth to check for vacuum leaks also.
  1. p0170-11 code
    By otto in forum Engine & Drivetrain
    Last Post: 20th February 2013, 21:27
  2. Replies: 16
    Last Post: 3rd February 2011, 22:35
  3. signum 1.9cdti 150 6speed error code u2103
    By shah1 in forum Electrical & ICE (including SatNav)
    Last Post: 12th December 2009, 08:21
vectra 2.8 v6 turbo fault code po170
p0170 hibakód opel
commom faults with signum 2.8 v6 turbo
p0170 fault code vauxhall vectra 2.8v6
p0170 vectra 2.8v6
