Results 1 to 3 of 3
Thread: O2 Sensor??
    Regular Member GrantAbs7's Avatar
    belfast
    Default O2 Sensor??
    Quick question folks.
    Had a diagnostic yesterday and the O2 sensor flagged up as not being present, can anybody shed some light as to what impact the O2 sensor not being present has on my car and how i can fix it/replace it.
    Thanks in advance
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    As far as I am aware there are typically 2 Lamda (O2) sensors mounted in the exhaust system - one in/near the exhaust manifold and the other after the cat.
    As a guide they look a little like a small sparkplug screwed into the exhaust pipe with a couple of wires coming off their plug. They simply screw in to the pipe and the plug clips on the top.
    If one is showing as 'not present' I'd start with 'which one?' ... then go for 'has the plug fallen off or been damaged?' before considering a possibly failed sensor.
    As a guide, if a sensor had failed I would expect 'out of normal range' readings from it rather than 'not there'.... leading me to think there's more chance it's the connection.
    South Central England
    10 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    It won't make a difference on your car but you can get them for about £40 and they are easy to change. Just check that the plug has not come lose.
  1. Replies: 3
    Last Post: 13th August 2012, 22:25
  2. P0141-04 o2 sensor heater circuit open (bank 1 sensor 2)
    By Mark1892 in forum Engine & Drivetrain
    Last Post: 3rd August 2012, 09:19
  3. Fitting & Installation of ABS Harness & brake Help sensor sensor
    By Elahi_786 in forum Suspension, Wheels & Brakes
    Last Post: 17th April 2012, 20:46
