Results 1 to 3 of 3
Thread: Rear Shocker Fault
    Mar 2011
    midlands
    Default Rear Shocker Fault
    Just sharing my recent problem with. For a while i have had a strange noise from the rear of my 2003 Vectra sxi. A noise that me and my missis have been calling the 'pigeon'. Obviously as it sound just as a pigeon does.
    After trying various common problems such as boot latch adjustment it turned out to be the o/s/r shock absorber. These are so easy to change and fairly cheap. Mine cost me £52 fron CES.
    I hope this thread will help someone as other post have helped me!
    Dec 2010
    Cumbria
    Did it squeek like a silvercross pram! Ours does! I thought it was the spring to start with. Changed em but its still there....also changed the ARBs to Powerflex...and its STILL there!
    Thinking it could only be the shocker now!
    Mar 2011
    midlands
    Yes i would say it is the shockers probably the drivers side 1 but you best to change the pair. Like i said they cost me £52 inc VAT for the pair. If you have access to a pit it does make it easier to change them but not too bad if not, 2 bolts and they off.
  1. Leaking shocker?
    By spukeyyy in forum Handling & Braking
    Last Post: 16th June 2011, 19:24
  2. Low N/S Rear End 'Shocker Deals Please'
    By Fireyfella in forum Suspension, Wheels & Brakes
    Last Post: 28th November 2010, 15:58
  3. Front shocker
    By biglee55 in forum Suspension, Wheels & Brakes
    Last Post: 22nd July 2009, 08:12
  4. A right shocker!
    By bigknill in forum Handling & Braking
    Last Post: 14th July 2008, 08:34
  5. Bit of a Shocker, even for TFL!
    By VXR_DV in forum General Chat
    Last Post: 1st May 2008, 10:19
