Results 1 to 10 of 16
Thread: Passenger wiper hitting bodywork
    Regular Member TonyR999's Avatar
    Cumbria
    Default Passenger wiper hitting bodywork
    Can the passenger wiper arm be adjusted so it does not hit the bottom of the windscreen and making a `slapping` sound when the wipers are working?...it's so bl**dy annoying, Especially with all this heavy rain we're having at the moment
    Regular Member Devil Nev's Avatar
    Jun 2006
    crawley
    check the nut holding wiper on the grooved spline ,had a similar prob with my corsa found the arm was not tight on the spline. also you could always move the arrm up one notch on the spline .
    Regular Member Maddog1974's Avatar
    Jul 2006
    Colchester
    I dont know if Vectra's are like this but most car you can just remove the nut of the wiper give it a little tug (the wiper that is!) and reposition it on the spline - tighten the nut and bingo!
    Regular Member simac's Avatar
    Wirral
    This same thing happened to my veccy and the dealer changed the wiper linkage under warranty straight away. I think there is a known problem with the wiper linkage.
    The passenger side wiper used to bounce off the bottom of the windscreen, it was really annoying and only did it when the wipers were on continuously. It didn't do it on one wipe or auto.
    as above, just remove the nutcap, loosen the 13mm nut, prise the arm up off the spindle and set it where you want it to park...retighten the nut and replace the cap... easy job to do..
    Cumbria
    Cheers all !! will do that tomorrow....if the damn weather will let me
    Jan 2006
    Bray Co.wicklow
    Default re-fitting wiper arm
    wiper blade was hitting the plastic bit of the windscreen so had to move it up a bit,heres a few pictures of how i did it.
    shows were it was hitting the plastic bit,were to find the nut ,and new position when finished.
    hope this helps some one else who has this problem.
    alan
    Nice job.. But AARRGGHH!!!...
    Use a spanner or a socket..... 5 holes are for gripping not undoing nuts....
    just another sad tool freak here..
    Regular Member andythilo's Avatar
    Oct 2006
    Saffron Walden
    Yeah and wash it too
    Oct 2006
    Saffron Walden
    And get a haircut
  1. Passenger side wiper has given up
    By GoblinKing in forum Bodywork & Interior
    Last Post: 30th April 2011, 14:52
  2. Wtf! Passenger Wiper Packed Up.
    By kev bux in forum Bodywork & Interior
    Last Post: 16th January 2010, 14:16
  3. passenger wiper faulty
    By IA76 in forum Vectra C / Signum Troubleshooting
    Last Post: 8th December 2009, 13:49
  4. Passenger wiper DEAD!
    By caravaner-tony in forum Vectra C / Signum Car Chat
    Last Post: 2nd February 2009, 23:22
  5. Passenger Side Windscreen Wiper
    By The Gas Man in forum Vectra C / Signum Car Chat
    Last Post: 25th May 2006, 21:22
nissan micra wipers banging
vauxall windscreen wiper hitting side of car y
vectra c wiper slap
vectra window wipers banging
adjust wiper park position on vectra c
vectra c wipers knocking
how to tighten wipers on vectra c
vauxhall corsa wiper blades hitting
2008 astra wipers hitting bodywork
