Thread: broken spring
    Regular Member iainm9438's Avatar
    Dec 2010
    Gloucester UK
    Default broken spring
    i know this a common issue and i had the news today, from the stealers doing my service, that i have a broken coil spring. they offered to replace it for £390but i reluctantly declined! lol.
    i will use this as the excuse to go down the lowered spring route so my question is.....which springs would you recommend on standard shocks (55 plate signum 2.2 design) or is it better to go down the spring and shock combination route?
    any help would be greatly appreciated.
    Regular Member phil67's Avatar
    Nottinghamshire
    Vehicle : Vauxhall
    Trim : Exclusive
    Engine : 1.8
    I had Eibachs on my C and i kept the original shockers
    Dec 2010
    Gloucester UK
    was yours 15mm lower ie sri spec before you went to eibachs? mine is design so has sri spec ride height.
    the reason i ask is that if i go for a set, is it 30mm lower than a standard height so i will only lower 15mm or will they lower mine by 30mm?
    Nov 2009
    Warwickshire
    Default Broken Spring
    Did same as phil67 on my design and it lowered by 30mm.
    Dec 2010
    Gloucester UK
    ok, great, thanks.
  1. Broken spring-what to do?
    By scotty84 in forum Vectra C / Signum Car Chat
    Last Post: 6th January 2011, 20:10
  2. broken o/s/f spring
    By bat30 in forum Vectra C / Signum Car Chat
    Last Post: 27th August 2009, 21:33
  3. broken spring!
    By the-wizard in forum Vectra C / Signum Car Chat
    Last Post: 2nd June 2008, 19:37
  4. Another broken spring...
    By shunter in forum Vectra C / Signum Car Chat
    Last Post: 28th May 2008, 12:31
  5. broken spring
    By toshiba in forum Suspension, Wheels & Brakes
    Last Post: 27th May 2008, 21:57
