Results 1 to 10 of 11
Thread: where can i take a constant +12v feed from for front parking sensors?
    Regular Member Mads's Avatar
    Ipswich,.UK
    Default where can i take a constant +12v feed from for front parking sensors?
    hi all
    as above really.. where can i take a constant +12v feed from for front parking sensors.
    the kit says to use brake light feed but i want to use it though a switch on my dash that i can turn on and off when req.
    can i just use any constant +12v feed though the on/off switch? if so i was thinking i could use the ignition live of cig lighter, this also powers my after market stereo?
    also i have brought 5amp inline fuse for main power to the sensor unit, is a 5amp fuse enough?
    thanks
    Regular Member bigbnlr's Avatar
    Belfast
    Take one from the fuse box mate, use one of these dead easy mate
    PRESTON
    You can use the live from the cig lighter, this is protected by a 30A fuse, so providing your total current draw for the stereo and sensors is no more than 30A it should work fine. I believe a 7.5A fuse is needed for parking sensors.
    Ipswich,.UK
    Quote Originally Posted by barney490 View Post
    maybe i shouldnt use the cig lighter one then as its powering my aftermarket stereo and also possibly satnav or iphone, dont know if i'd be overloading that one? will take 5amp fuse back and get 7.5amp.
    Ipswich,.UK
    right im thinking im going to use socket 2 pin 4 for powering the sensor unit which is a ign live with 7.5 amp fuse, can i also power the front senors to this with the on/off switch for them in between and put the return of that switch to the blue wire on sensor unit (which would of been brake feed) will use reverse feed for rears.
    does this sound ok??
    http://www.vectra-c.com/forum/showthread.php?t=11893
    Ipswich,.UK
    dp.
    May 2011
    Birmingham
    Could splice it off the feed for the climate/air con panel, Its a nice easy part to just pop out, pleanty of room to work behind it too.
    Regular Member MrDerv's Avatar
    Nov 2011
    North East (Beamish)
    Quote Originally Posted by Dave1.9 View Post
    Don't do this unless you are piggy-backing it from the fuse panel
    Ipswich,.UK
    Quote Originally Posted by MrDerv View Post
    could i do what i said in the earlier post? post 5
    Nov 2011
    Yes, you'll need one of these
    http://www.ebay.co.uk/itm/Add-Circui...item27c205dc69
    You can take a live feed from the fusebox beside the glovebox, just check which fuse is for your Cig lighter and use the piggyback there to provide your switched live.
  1. front parking sensors
    By Knight Rider in forum Electrical & ICE (including SatNav)
    Last Post: 13th October 2012, 14:21
  2. front parking sensors
    By woodze in forum Vectra C / Signum Car Chat
    Last Post: 13th May 2009, 22:35
  3. 20 amp battery constant feed
    By goonturbo in forum Electrical & ICE (including SatNav)
    Last Post: 6th March 2009, 01:15
  4. Live feed for parking sensors..
    By macdad in forum Electrical & ICE (including SatNav)
    Last Post: 19th December 2008, 23:07
vectra c2 where can take 12v
