Thread: Headlight Restoration ?
    Regular Member Led's Avatar
    Kings Langley
    confused Headlight Restoration ?
    My 54 plate Vectra's headlights are now looking crap - the top 20% has gone greeny/yellow (like verdigris) and was wondering if these "Headlamp Restoration" kits are OK or just a gimmic ??
    http://www.meguiars.co.uk/product/39...storation-Kit/
    I've heard that some people wet sand them back, so apart from new units what is the best way forward ?
    I use Megs products for cleaning my car and now the headlights are letting it down
    Regular Member daddyjay's Avatar
    Jan 2010
    poole
    Vehicle : vectra facelift
    Trim : sri
    Engine : z20net 2oltr turbo
    Year : 57
    Mileage : 38200
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    done it on my chrome ones, came up a treat.
    leeds
    I wet sanded the headlights on my GFs Honda last weekend and they came up like new. Light output is better as well now
    Its not as hard as you might think either.
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 65500
    Before you try wet sanding just try polishing them with cutting compound and a machine polisher.
    Woodbridge
    The 3M kit is very good. If you have a DA, try what DasArab says above. If you dont have a machine polisher then I think your are kind of stuck. But with a bit of effort you can get them looking spot on with wet and dry and a bit of cutting compound.
    Hanging Heaton
    23 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 140k
    I used cutting compound and a DA last year, it's started to come back...
    Def using some wet and dry this time...
    Kings Langley
    I have a DAS6 and a Dremel with pads, I've also got a small array of polishes and comounds too.
    After looking at the headlights the main area of concern seems to be the top 15% of the headlight.
    There is no detrimental affect of the beam intensity just a naff looking headlight.
    What causes it - wax, polish etc as it's possible that it's where I've waxed the car (being carless with the applicator and getting some on the headlight) ?
    Regular Member dlp's Avatar
    Mar 2011
    Cottesmore, Rutland
    I have this issue too (52 plate vec) and am planning to have a crack at the How 2 in the not-too-distant-future.
    Personally I think this is caused by road grime (inc salt etc) gradually breaking down the surface of the lights. I have xenon main beams so the washer solution/heat combination may also be a factor on mine...
    Feb 2011
    Selby
    It most probably is caused by the tiny bits of soil, sand, grit, salt kicked up by vehicles in front of you, firing into the plastic headlight covers at 70mph leaving tiny pits, leading to the dull appearance. Over time the pits get algae growing in them, causing the greenness.
    The reason why some people's headlights suffer more than others is probably down as much as anything to how clean the roads are where they drive, how fast they drive, and how close they drive to the car in front.
  1. headlight restoration
    By Swedge in forum Detailing and Car Care Discussion
    Last Post: 16th December 2012, 22:42
  2. Punto Headlight Restoration
    By Das in forum Detailing and Car Care Discussion
    Last Post: 9th August 2012, 00:54
  3. MK 2 Cav Restoration
    By Vaux-Man-G in forum The 'Off Topic' room
    Last Post: 24th March 2009, 10:18
vectra c headlight restoration
headlight restoration kings langley
Restore vectra c headlight
