- ^^^^^ it for a veccy c 2.0 turbo looking to do a full sarvice
and best place to get all parts from
oil
oil filter
air filter
pollen filter
fuel filter, possibly, I would change it if doing a full service
spark plugs if petrol engine
I would also check and replace the following if needed,
Brake pads, front and rear
brake discs, front and rear
anti freeze
brake fluid
tyres
Battery
No doubt I will have forgotten something, and someone will nodoubt point it out.
3.2 v6 Signum and loving it 😁
how much do i need to put in for brake fluid and anti freeze
lol it do`s not like stopping
As above but also bleed brakes through as brake fluid is hydroscopic meaning it absorbs moisture over time.
If your unsure when the coolant was last change do that to. It has a 5 year life. But also helps lubricate water pump etc aswel as dissipate heat from engine more efficiently so worth putting new stuff in.
Also check all bushes brake lines, fuel lines etc.
brake fluid not been done from 33k it now on 93k
