Thread: Side indicators!
    Regular Member bbdp's Avatar
    Feb 2012
    Essex
    Default Side indicators!
    Bought some chrome bulbs for the signum however when I went to fit them it looks like the lenses are glued on in the same way the badges are? Is this correct or has someone done something stupid to mine?
    The how 2 doesnt say anything about this and I'm worried that I'll ruin them!
    Regular Member insignia28's Avatar
    Mar 2011
    Warrenpoint, NI
    they really shouldnt be, should be a wee clip behind the lense that a fine flat blade screwdriver will release. btw, there is an orage filter in the lens so it may not be much point unless your going to break them apart to remove it
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Someone probably broke the clip and glued them on.
    They should clip in
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    They should clip in
    Feb 2012
    Essex
    But it looks like the same foam pads that hold the badges on and it's the same both sides! I can't believe it would be so neat if someone had broken it previously?
    Anyone done this on a facelift signum?
    Mar 2011
    Warrenpoint, NI
    they are the same as a preface. the pads are there to protect the paint work from teh hard plastic. they are a very snug fit tbh, it took a bit of work when i took mine off to fit the white repeaters
    Feb 2012
    Essex
    Quote Originally Posted by insignia28 View Post
    So it's not glue then?should come away in one piece if I take my time?
    Oct 2007
    Ripon
    I wrapped an old credit card size piece of plastic in lens cloth and slid it behind indicator and paint work and it presses clips in and you can get it out. I think door to front of car was the best direction to go.
    Take it easy though to avoid marking paint.
    VIP-Member puppet's Avatar
    East Ayrshire
    10 Post(s)
    Vehicle : Insignia 1.8 SRi
    Trim : VX Line Red
    Engine : 1.8VVT
    Year : 2011
    Should do, yes.
    If I recall correctly, the best way to remove them is to slightly prise out the end of the indicator nearest the front of the car first, then sort of apply pressure on the whole assembly towards the rear of the car, then pull the indicator out.
    Kinda hard to explain, but it's just how the securing clips work.
    Feb 2012
    Essex
    Thanks guys! I'll have a go tonight
  1. Side Indicators
    By Fitzy-2.0T in forum Vectra C / Signum Car Chat
    Last Post: 12th July 2012, 09:53
  2. side indicators
    By Tam80 in forum Bodywork & Interior
    Last Post: 26th September 2010, 13:24
  3. Remove side indicators
    By matreya in forum Bodywork & Interior
    Last Post: 15th March 2010, 22:30
  4. Side indicators
    By suggs1971 in forum Vectra C / Signum Car Chat
    Last Post: 21st November 2009, 14:08
  5. signum side indicators
    By stevie1 in forum Vectra C / Signum Car Chat
    Last Post: 15th April 2009, 21:27
