Page 1 of 5 123 ... LastLast
Results 1 to 10 of 42
Thread: Vectra not well!!
    Regular Member djr69uk's Avatar
    Midlands
    Default Vectra not well!!
    Hi all
    I've not been around for a while, mostly thanks to my missus for leaving at Xmas me after 10 years together!
    Anyway... my faithful Veccy has properly chucked its toys out of the pram this morning! Drove to work and pulled into the car park and noticed the engine not sounding brilliant, down on power, rattling badly and the EML is now on. It sounds terrible - like tractor terrible.
    It will restart after a few cranks. I've pulled the injector plugs on all 4 cylinders and 1 and 2 don't appear to make much difference. 2 seems to change the engine tune a little bit but 1 is completely dead. So it's running on 2 and a bit cylinders. The question is why...? If it was just 1 cylinder then I would be thinking injector or injector wiring - but it's affecting two and sounding terrible - so perhaps something internal mean i no longer have compression on 2 cylinders?
    Oil and water levels are fine. EGR valve was cleaned a couple of weeks ago. I've disconnected and reconnected plenty of plugs in the engine bay, but to no avail.
    Any ideas guys?
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 141000
    Quote Originally Posted by djr69uk View Post
    Hi all
    Any ideas guys?
    sorry to hear about your other half
    not good at xmas time
    any code readings you can give us?
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    What engine have u got bud?
    Regular Member rjw's Avatar
    Oct 2010
    cornwall
    Sounds like Head Gasket failure to me? gone between the 2 cylinders with no compression!
    Regular Member XPCobra's Avatar
    Dec 2010
    Glasgow
    Vehicle : Vauxhall Vectra Hatch
    Trim : SRI with added X-Pack
    Engine : 1.9 16v 150
    Mileage : Near 100K
    Get a code reader on it, No point in wasting time guessing
    Midlands
    It's the 1.9CDTI 150. Sorry I might have misled people... I don't know if there is a compression problem... and it is cylinders 3 and 4 that are affected - not 1 and 2.
    I don't think it's HG... no mayo... no leaks and water and oil levels all absolutely fine.
    Now I've previously done a repair on the injector connector wiring for cyl 3... the usual common problem... the guy in the garage thinks it might be an issue with the wiring that is affecting both 3 and 4. Not sure at the mo, they are going to check it out. It does sounds like a bag of spanners at the mo though! It's possible that some of the wiring has become damaged somehow I guess.
    Oct 2010
    cornwall
    If the gasket has gone between two cylinders you often dont get mayo, but wont fire on those cylinders. you only get the mayo if gasket goes between cylinder and water cooling system,
    Northampton
    Engine : A20DTH
    Mileage : 88000
    May well need to change the other injector plugs and cables, hopefully that should sort it. Get the kit from VX with the new blue plugs
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 141000
    Quote Originally Posted by rjw View Post
    thing is he says oil and water are fine
    need codes
    Oct 2010
    cornwall
    Quote Originally Posted by vectra ste View Post
    need codes
    oil and water will be fine if gasket gone between two cylinders,
    I have attached a simple diagram I was sent by my mechanic by email that he drew on paint of a gasket. He used this diagram to explain to me why i didnt get mayo oil when my head gasket went on my old Rover.
    This below is the explanation he emailed me and i have simply copy and pasted his email to me.
    If gasket gone where i've scribbled Red you will lose compression on two cylinders, but will not get damaged oil or water. If gasket goes where scribbled green you will get oil and water mixed and damaged, and only reduced compression on one cylinder.
  1. mods could i do to my vectra 1.9cdti vectra suggestion of cheap vxr bumpers
    By lynchy-- in forum Vectra C / Signum Car Chat
    Last Post: 6th January 2013, 00:17
  2. Vectra b rose bush for vectra c rear upper control arm
    By supernova_abh in forum Suspension, Wheels & Brakes
    Last Post: 14th September 2012, 19:26
  3. Silver Vectra (Vectra C Sticker) Southport Ocean Plaza DU56
    By mishima in forum Spotted or put a flyer on a Vectra C/Signum or Insignia?
    Last Post: 29th September 2011, 23:25
  4. Replies: 9
    Last Post: 17th July 2009, 12:07
