Thread: Headlight washers - never worked!
    Vehicle : .
    Trim : .
    Engine : .
    Year : .
    Default Headlight washers - never worked!
    Sorry if this is in the wrong section, mods please move if it is.
    Ever since owning the VXR the headlight washers have never worked, not really bothered me that much - but as they are there I would now like them to work.
    I can pull out the jet washer cover quite easily by hand to expose the jets with very little resistance so they dont appear to be stuck.
    I thought first port of call would be the fuse, but this appears to be fine - if anyone can confirm the fuse number and location just to make sure I'm looking at the right one.
    Other then that any other suggestions to trace the fault please?
    Cheers peeps
    Andy
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Do they only work when the headlights are on?
    Vehicle : .
    Trim : .
    Engine : .
    Year : .
    dont work at all.
    They are meant to work when the headlights are on and you pull the stalk (oh er missus!) towards you to wash the windscreen, it then washes the headlights
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 65500
    Relay maybe? White one at top of fuse box. Fuse is the 30amp one in position 13 or 14.
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    Headlight washers only work with the headlights on, that's by design.
    Fuse is number 14 from memory (30A) and the relay is the white one right at the back of the small fuse box under the bonnet (assuming it's the same as the pre-face).
    Check the plug going onto the bigger pump on the bottle too.
    Is it possible someone's turned them off with Tech2 because they didn't like them? They have to be marked as present on the system in order to work.
    Regular Member lofty's Avatar
    @home
    Vehicle : Vectra C Estate
    Engine : 1.9 CDTi
    it's the white relay in the engine fusebox that controls the headlight washers
    Vehicle : .
    Trim : .
    Engine : .
    Year : .
    cheers guys, i'll replace the relay and see if that sorts it - where can I get hold of one? any links
    ta
    Check the fuses around F14 mate - the facelifts have a different fuse numbers than the prefacelift and I spent ages trying to figure out why mine weren't working using a prefacelift haynes manual...
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Try get down Saturday mate we will sort it for ya and the other bits aswell
    Vehicle : .
    Trim : .
    Engine : .
    Year : .
    Sorted it! It was fuse F13! I was looking at the wrong one. Lol
    Sent from my iPhone 4 using Tapatalk
  1. Headlight washers don't pop out
    By throdo in forum Bodywork & Interior
    Last Post: 27th January 2012, 14:32
  2. headlight washers??
    By vauxhall-john in forum Bodywork & Interior
    Last Post: 4th January 2011, 13:21
  3. headlight washers.
    By Netstar in forum Bodywork & Interior
    Last Post: 2nd March 2009, 16:18
