Results 1 to 10 of 11
Thread: rear disc heating up
    Regular Member coooky's Avatar
    May 2011
    washington
    Default rear disc heating up
    when i drive my car the drivers rear disc gets really hot
    could this be the caliper sticking on ??
    thanx
    wirral
    33 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Sticking caliper yeah.
    Seems to be common on the vec
    Regular Member MrDerv's Avatar
    Nov 2011
    North East (Beamish)
    Likely a seized or sticking caliper.
    Take the caliper off and ensure the slide bolts are free. If they are stiff then there is your culprit
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    More than likely mate, it'll either be the cable sticking, the piston sticking or it could be that the metal around the rubber slides has corroded tightening the rubber around the caliper slide pins hth
    May 2011
    washington
    cheers guys
    Regular Member wardy23's Avatar
    Nov 2011
    North Yorkshire
    Vehicle : vectra
    Trim : sri
    Engine : 2.2
    Mileage : 64000
    if it the pins can they just be greased up ???
    Dec 2011
    Seaham
    If they are like most brakes, carefully clean them up with some grit paper and apply a thin coat of either copper slip or silicon rubber grease (unfortuntaley this sint a job for chain lube).
    Make sure there isnt too much on a light coating will be enough.
    If you continue to drive you may warp your discs.
    Regular Member Das's Avatar
    Turdsville
    35 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Quote Originally Posted by wardy23 View Post
    You just need to push the plastic slide guides out and using a piece of sand paper remove the corrosion. Then clean out the insides of the plastic guides and the slides and refit then some copper grease on the slides and refit.
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Why, oh why, oh why, is it always the drivers side...
    If the rear offside is overheating, check the front nearside brake and compare
    Then compare the front pads, you may fnd the front nearside pads have been doing more work than the front offside pads as a result
  1. Rear heating & rear socket
    By smiler1982 in forum Troubleshooting
    Last Post: 11th January 2012, 10:53
  2. Heating temperature control not working - Full heating permanently
    By jratcliffe3 in forum Electrical & ICE (including SatNav)
    Last Post: 31st January 2010, 23:46
  3. rear windscreen heating element
    By shy_stag in forum Vectra C / Signum Car Chat
    Last Post: 18th November 2008, 22:11
  4. Rear heating window question..
    By Jim Bob in forum Vectra C / Signum Car Chat
    Last Post: 16th October 2008, 16:52
  5. Rear Heating Ducts in Face Lift SRi - Possible?
    By vec1975 in forum Vectra C / Signum Car Chat
    Last Post: 22nd February 2008, 12:11
