Results 1 to 10 of 17
Thread: Just clicks :(
    Oct 2009
    southport
    Vehicle : vectra
    Trim : sri
    Engine : 3.2 v6
    confused Just clicks :(
    Hi all, right vectra has been sat for about a year before I put it away the problem started but now has got worse, go to start it and just clicks, battery is fine rac said it was starter motor so changed starter motor and still not solved the problem!! It bumps fine and when run for abit and I turn it off it will sometimes turn on key and start then next day click again :/ any help guys? Garage said probs ignition switch but thought get some advise on here
    Cheers Ben
    Regular Member rjw's Avatar
    Oct 2010
    cornwall
    Sounds like a jammed starter motor, especially common on cars left standing for a long time
    Sent from my HTC Sensation Z710e using Tapatalk
    Oct 2009
    southport
    Vehicle : vectra
    Trim : sri
    Engine : 3.2 v6
    That's what I thought but I have changed starter motor over with a new one and tested before it went in but still the same, it's a 3.2 v6 if that makes a difference
    Oct 2006
    North Yorkshire
    Vehicle : Astra
    Trim : GTC VXR
    Engine : 2.0 Turbo Petrol
    Year : 2015
    Mileage : 3,200
    You sure its not the battery? sounds like the same symptons i had with mine and the battery was shorted out and not holding a charge, also have you checked the alternator as that could be a cause and not charging the battery.
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    It's the battery if it's just clicking mate
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Need volt drop the cable to check it hasn't got high resistance.
    First check batt condition and connections
    Oct 2009
    southport
    Vehicle : vectra
    Trim : sri
    Engine : 3.2 v6
    Battery is fully charged, had the rac out and they checked battery said it was fine even put there jump pack on and put earth straight to engine block and still clicked they said starter motor seized but now changed still the same!! It does sometimes go on the key but very rare!!
    Oct 2009
    southport
    Vehicle : vectra
    Trim : sri
    Engine : 3.2 v6
    Rac also had volt meter out and checked everything said it was all fine
    Oct 2006
    North Yorkshire
    Vehicle : Astra
    Trim : GTC VXR
    Year : 2015
    Mileage : 3,200
    I would still try and borrow a battery and see if it makes any difference!
    Oct 2009
    southport
    Vehicle : vectra
    Trim : sri
    Engine : 3.2 v6
    I could maybe try differant battery, tbh it's had 2 different ones in and still same, even if battery was low etc wouldn't it jump off a car with leads or a jump pack that rac used?
  1. CDR2005 Clicks 5-10 For Seconds?
    By AdeV6 in forum Bodywork & Interior
    Last Post: 15th May 2012, 09:40
  2. Not starting just clicks!
    By frigosolver in forum Engine & Drivetrain
    Last Post: 5th February 2012, 08:55
  3. Door 'cracks/clicks'...
    By nikroc in forum Bodywork & Interior
    Last Post: 31st August 2011, 12:18
  4. dash whirr's and clicks
    By Derek Mc in forum Vectra C / Signum Car Chat
    Last Post: 4th October 2010, 19:06
  5. Clicks on the key
    By OysterD in forum Engine & Drivetrain
    Last Post: 8th November 2007, 09:25
