Thread: 2.0t sri hod do i get turbo chatter?
    Jun 2011
    weling kent
    Default 2.0t sri hod do i get turbo chatter?
    hi, i have a 2003 2.0t sri and was just wondering how do i get turbo chatter?
    ive got on it at the moment k&n induction kit, bailey dump valve, 3inch straight threw exhaust just fitted 2 months ago cost me £545 fitted by dku exhausts, sounds the nutts but just want that chatter noise as i heard it on a vxr astra the other day.
    also can anyone help me, i have my management light on witch is the exhaust tempreture sensor , is there any way i can bypass this. as ive been told this its only on the 03 and 53. thank chris
    Regular Member MrDerv's Avatar
    Nov 2011
    North East (Beamish)
    You don't want chatter, kills the turbo.
    But essentially it involves disconnecting the recirc BOV so that the turbo goes into stall causing the wastegate to "chatter". The side efect is both turbo wear, and compresser surge as the boost vents back towards the airflow meter
    Nov 2011
    Forgot to mention, turbo chatter can be heard a lot in WRC, but they consider turbo's to be a thow-away part, and due to the quick gear changes, a BOV just isn't quick enough in a WRC application. Yes the noise sounds nice, but a thhe cost of premature turbo wear, it's really not worth it
    Regular Member Super T's Avatar
    May 2007
    On the Levels
    Just buy a new et sensor!! When i had my downpipe fitted mine was also damaged by the installers as they did not know it was there.They are only looking for 2x lamda sensors not 3x sensors. Have a word with your local steelers and see if you can have it deleted from the ems. HTH
    Jun 2011
    weling kent
    thanks mate will do
    Mar 2012
    N. Ireland
    Trim : Sri XP
    Engine : 1.8 VVTi
    why would you want turbo chatter its a bad thing, get a BOV
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    A remap will get ya chatter lol
  1. Replies: 19
    Last Post: 6th September 2014, 13:54
  2. 1.9 CDTi wastegate chatter???? Induction kit....
    By Vectra Adz in forum Diesel Engine related
    Last Post: 7th July 2012, 12:27
  3. How to make my 1.9CDTi Wastegate Chatter
    By dannybl1990 in forum Diesel Engine related
    Last Post: 19th June 2012, 02:50
  4. Engine chatter.....dreaded DMF and clutch issues
    By marky2027 in forum Engine & Drivetrain
    Last Post: 24th February 2012, 16:50
  5. 19.cdti chatter noise help anyone at all
    By 0114NIGEL0114 in forum Tuning
    Last Post: 25th August 2011, 10:15
