Results 1 to 2 of 2
Thread: Dual Mass Flywheel symptoms
    Jul 2011
    Devizes
    Default Dual Mass Flywheel symptoms
    Hi there. Just wanted to check if dual mass flywheel can cause issues with steering wheel wobble and slight vibrations through the peddles? I thought it was the balancing on front wheels, but just been in for a service at vauxhall and they said Ive got dual mass flywheel problems. Slight noise when clutch is depressed, nothing much else or further symptoms. I might be putting two and two together and making five!
    Many thanks.
    Mark
    May 2006
    scotland
    I have dmf issue and I had wobble at certain speeds on steering, however, the two were completely unrelated as when I asked a fast fit outfit to check wheel balance, one wheel was way out. Once the two front wheels were balanced, streeing was fine.
    My dmf problem does however cause my car to vibrate slightly at idle i.e. feels like a slight misifire but it aint a misfire, its dmf out of balance. My dmf, at present, only makes audible noise with clutch fully released and for example under load from air con.
  1. Dual Mass Flywheel
    By hairy31 in forum Vectra C / Signum Car Chat
    Last Post: 27th February 2010, 23:15
  2. Dual Mass Flywheel - HELP!
    By alibeardrfc in forum Vectra C / Signum Troubleshooting
    Last Post: 11th December 2009, 10:37
  3. Dual Mass Flywheel Symptoms
    By dave16v in forum Vectra C / Signum Car Chat
    Last Post: 20th March 2008, 23:45
  4. symptoms of a dual mass fly
    By zeadly in forum Engine & Drivetrain
    Last Post: 30th July 2007, 23:21
