Thread: Cold starting woes - Chapter 2
    Regular Member Barlow's Avatar
    Jan 2012
    Chester
    Vehicle : Nissan 350Z GT
    Engine : 3.5 V6
    Year : 06
    Mileage : 50,000
    Default Cold starting woes - Chapter 2
    So I've replaced the battery for a new'un, and that helped..for a while, but I'm basically back to cranking the hell out of it.
    Now the glow plugs don't illuminate in this warm weather, and that's helped me figure out what the problem could be.
    In the morning I turn the ignition on and don't crank. Then, off, then on, then off...etc. Appx 4 -5 times, then the car starts OK.
    I'm thinking that the diesel is running back down the pipe to the tank...or thereabouts.
    So I've ordered a 10mm non-return valve from ebay. Not sure whether to put it near the filter housing or further down the line, so any advice is welcome.
    I've also ordered some 3.2mm braided to do the leak offs. I've heard lots of people say this could be the problem but in honesty, I've noticed (from googling) that it very rarely fixes the issue.
    West
    Try replacing the coolant temp sensor for the pre heat system... my glow plug light illuminates in this weather first thing in the morning
    Jan 2012
    Chester
    Engine : 3.5 V6
    Year : 06
    Mileage : 50,000
    That's on the thermostat isn't it? I only replaced that appx 6 weeks ago.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    If the fuel is returning back down the pipe there must be a air leak somewhere in the pipes
    Jan 2012
    Chester
    Engine : 3.5 V6
    Year : 06
    Mileage : 50,000
    Quote Originally Posted by merikiito View Post
    Well if it is I would say it's at the connections to the fuel filter housing. It looks poorly designed.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    are you sure there are no leaks, there is a water release valve under the filter that might be loose (I think) plus make sure there is no diesel around the injectors etc
    Is it the 150 version? If so I am going to have a look at mine and see if I can spot anything that might help you
    Jan 2012
    Chester
    Engine : 3.5 V6
    Year : 06
    Mileage : 50,000
    No, it's a 120 matey.
    Injectors are dry. It's hard to check for air leaks around those hoses as you probably know.
    I had the idea to bind it up with PTFE tape and see if that helped. It would then at least point me to the fault.
    I have a strong feeling diesel is running back to the tank...which would mean an air leak is the likely cause.
    At least a non-return valve will stop it going anywhere regardless of an airleak.
    Jun 2011
    Herts
    sometimes it only flashes on- but it does come on in mine too....
    Fitted a new stat and then did glow plugs and temp sensor/sender.
    I wasn't having any probs before I did it as she always started on the first attempt, but now she never takes more than 2 seconds to fire and is almost instant when the glow plug light stays on for a few seconds
    Regular Member haye2412's Avatar
    Aug 2009
    portland
    My son who is a Vauxhall tec put a valve on my old 2.2 dti under the bonnet over by off Side of engine
    Jan 2012
    Chester
    Engine : 3.5 V6
    Year : 06
    Mileage : 50,000
    Quote Originally Posted by haye2412 View Post
    I think the pump on the 1.9 is on the nearside.
    Did it fix your starting issues?
  1. Starting in the cold
    By Rebellion8878 in forum Vectra C / Signum Car Chat
    Last Post: 20th December 2010, 22:15
  2. Vectra 1.9CDTI 150 - Cold Starting Woes
    By robdd1 in forum Vectra C / Signum Car Chat
    Last Post: 8th February 2010, 17:39
  3. Bad Starting From Cold
    By PAULMAC77 in forum Engine & Drivetrain
    Last Post: 7th October 2008, 11:48
  4. Starting cold Problems
    By vectraspain in forum Engine & Drivetrain
    Last Post: 13th April 2007, 18:23
vectra c 3.2 v6 water temperature sensor and hard starts
vectra c 3.2 cold start injectors
