Results 1 to 3 of 3
Thread: Removing fuel filter pipes
    Regular Member rockafella8587's Avatar
    Nov 2011
    Akrotiri, Cyprus
    Default Removing fuel filter pipes
    I need to change my fuel filter on my 1.9 cdti and ive read the how 2 on what needs done but im after a bit more detail on how to release the 2 fuel lines. It says just to use a flat headed screw driver on the blue connectors but i need to know exactly where im putting the screwdriver and in which direction do i apply pressure?
    I dont want to steam in there and break them without knowing exactly how to release them.
    Nov 2010
    East Midlands
    Trim : design
    Quote Originally Posted by rockafella8587 View Post
    No don't put too much pressure on them - they damage easily - if you put a small screwdriver on each little blue tabs and gently push them inwards pulling the pipe at the same time the clips will release and the pipe will come out
    Nov 2011
    Akrotiri, Cyprus
    Excellent, cheers mate! Will give that a go, will be gentle tho lol!
  1. Replies: 19
    Last Post: 30th May 2012, 15:53
  2. 1.9 CDTI Fuel Leak Off Pipes.
    By felixx in forum Engine & Drivetrain
    Last Post: 6th February 2011, 18:28
  3. Removing tail pipes ....
    By MAF 3.2 V6 GSi in forum Vectra C / Signum Car Chat
    Last Post: 1st August 2007, 18:49
  4. Any advice on removing & replacing Fuel Filter ??
    By Cilldara1 in forum Engine & Drivetrain
    Last Post: 2nd July 2007, 07:17
  5. Fuel pipes
    By markm in forum Vectra C / Signum Car Chat
    Last Post: 29th April 2007, 20:19
