Thread: Thermostat on vectra 1.9 cdti estate (120)
    Regular Member SarahP's Avatar
    Nov 2011
    Buckinghamshire
    Default Thermostat on vectra 1.9 cdti estate (120)
    i (well not me persoanlly)am due to change the thermostat as im sure its stuck open (someone said that on this forum ) where is it on the 120 and is it difficult to change (with housing) ALSO, if it is tricky are there any tips to over come this
    Nov 2011
    Buckinghamshire
    anybody????
    Nov 2010
    East Midlands
    Trim : design
    Quote Originally Posted by SarahP View Post
    Hi, Its a right pig of a job because of a bracket on the stainless cooler that is attached to the lower fixing bolt of the Thermostat - loads of previous posts have a look at http://www.vectra-c.com/forum/showthread.php?t=158982
    Nov 2011
    Buckinghamshire
    Do you have to take the egr cooler off then?
    Nov 2010
    East Midlands
    Trim : design
    No - its just the bracket on top of the cooler that causes the problem - and its simpler to cut this off
    Regular Member Chris B's Avatar
    Jan 2012
    Essex
    Quote Originally Posted by alcutler View Post
    Yep, I managed to get my dremmel in there, then broke the cutting disc but had sufficiently cut enough to be able to break it......... other than this damned bracket its a breeze!
    Regular Member vecsxi's Avatar
    Nov 2005
    liverpool
    if you find any short cuts you need to do them as this job is a hand destroyer. also if you have to remove the egr cooler its a real rain putting it back on as the gaskets dont go back on easy at all.
    im faced with having to do this a second time soon as its stuck open again
    PRESTON
    It makes access easier if you also remove the vac pump, 3 bolts and it's off,, just get a new gasket from the stealers before you start.
  1. vectra 1.9 cdti sri 2006 120 bhp thermostat removal
    By jayhirst12 in forum Engine & Drivetrain
    Last Post: 5th December 2012, 20:19
  2. Vectra C 1.9 cdti estate
    By winton40 in forum Vectra C / Signum Troubleshooting
    Last Post: 25th May 2011, 16:36
  3. vectra cdti 150 estate
    By jhorsf in forum Engine & Drivetrain
    Last Post: 16th August 2009, 19:43
  4. Vectra SRI CDTI 150 XP Nav Estate
    By pacarcher in forum How much is it worth? (THIS SECTION IS NOW CLOSED)
    Last Post: 11th May 2008, 20:46
  5. my new vectra cdti 150 estate
    By learoy69 in forum Vectra C / Signum Car Chat
    Last Post: 3rd March 2008, 22:57
