Thread: Advice needed on removing door panels....
    Regular Member ridgers84's Avatar
    Jan 2012
    Derby
    Default Advice needed on removing door panels....
    Ok so went about trying to replace the standard speakers today and fell at the first hurdle!!!!
    I got the torx screws out ok and 'popped' the door off the clips..... But I can't for the life of me figure out how to pull the panel up and over the door lock. Its like its glued or something. I know I need to disconnect the lock cable and another cable but was going to do this when the panel was off and free cos I can't pull it back far enough to see where to disconnect them. (if that makes sense!)
    I've read the how2 and still no joy!
    Any ideas???
    Administrator plasma's Avatar
    On the Forum
    405 Post(s)
    Engine : 150
    Mileage : 74000
    make sure the window is down gives you better grip on it but essentially the door card does have to come up and off can be a right pita if never removed before, then you can disconnect the door release cable
    Jan 2012
    Derby
    So if I keep tugging at it nothing will break?
    On the Forum
    405 Post(s)
    Engine : 150
    Mileage : 74000
    just be careful as you could probably already tell the door card like to try to fold up on itself at the join
    Regular Member rockafella8587's Avatar
    Nov 2011
    Akrotiri, Cyprus
    Do you need to disconnect the electric window/mirror switch first? ie, pop it off and disconect the connector. Had to do that on my last car so might be the same
    Jan 2012
    Derby
    Quote Originally Posted by rockafella8587 View Post
    I tried taking it off but couldn't pull the panel back far enough to see the connector, I'm guessing there is a clip or clasp?
    Nov 2011
    Akrotiri, Cyprus
    When I did it on my last car (not a vauxall) I had to prise the actual switch out of the door handle where it is mounted and then disconnected the switch so the door card could be lifted up and off. Im not sure the vectra is the same but id imagine it might be. Someone on here must know for sure bud
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    The switch pops out the door card and pulls up, then you can disconnect the cable from it
    Jul 2010
    This is London baby
    Vehicle : Dodge Journey
    Trim : SXT
    Engine : 2.0Tdi (VW Engine)
    Year : 2010
    Mileage : 53000
    you have taken out 5 torx screws, 3 at the bottom of door and 2 behind the door pull.
    Jan 2012
    Derby
    Quote Originally Posted by cliomjh 102 View Post
    Yup
  1. Door panels
    By Steve01252 in forum Electrical & ICE (including SatNav)
    Last Post: 24th July 2011, 20:18
  2. Replies: 9
    Last Post: 20th June 2011, 13:07
  3. Driver door module advice needed..
    By j2cams in forum Electrical & ICE (including SatNav)
    Last Post: 17th April 2011, 22:16
  4. help needed on removing back door glass please guys!!
    By maddogwhite27 in forum Bodywork & Interior
    Last Post: 30th November 2008, 22:43
  5. Door panels
    By CraigsIrmscherSRI in forum Styling
    Last Post: 30th September 2006, 20:25
dhow to remove door panel off a vectra
