Results 1 to 10 of 15
Thread: Wide ratio g/box in an Sri ?
    DURHAM
    Default Wide ratio g/box in an Sri ?
    Would it be advisable to fit a F17w394 to a 2006 1.8 Sri,and is it a huge difference in performance . The driver (my dad) never thrashed the old box so at a guess I think he won,t notice the difference .
    Thanks.
    Feb 2011
    Selby
    With the wide ratio gearbox you'll find that you can do 60mph at 2000rpm in 5th gear, and in fact rarely need to go over 2500rpm ever in normal driving.
    Which is why it's fitted to the non-sporty Vectras like the LS, Club, Elegance and Elite.
    I've got the ratios somewhere so I could work out the different speed/rpm ratios if you like.
    Regular Member bigbnlr's Avatar
    Belfast
    I went the other way in my old vec, putting a close ratio box in. The difference was night and day.
    DURHAM
    Thanks for the reply.
    Here,s the details from box he,s bought ,A 12532F17W394.
    He was told it had come off a facelift 06 Sri, but it was true the code would be F17C.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Engine may start to struggle with that box in higher gears.
    Feb 2011
    Selby
    Ok - here are a few rpm/speed figures based on the gear ratios.
    This is for my 2004 1.8 Dual Fuel Elegance, so F17W gearbox with 215/55R16 tyres. Don't forget that air resistance means that speeds above 70mph will be less. Top speed is actually around 120mph.
    Speeds at 2000rpm, 4000rpm and 6000rpm
    1st gear: 12mph, 25mph, 37mph
    2nd gear: 23mph, 47mph, 70mph
    3rd gear: 35mph, 69mph, 104mph
    4th gear: 48mph, 97mph, 145mph
    5th gear: 61mph, 121mph, 182mph
    With the F17C close ratio gearbox (eg in an SRI) and the same tyres:
    2nd gear: 21mph, 43mph, 64mph
    3rd gear: 32mph, 65mph, 97mph
    4th gear: 41mph, 82mph, 122mph
    5th gear: 51mph, 103mph, 154mph
    Hence what you'll notice is that you'll be going slightly faster in gear than you were before for the same rpm, at the expense of acceleration. So you'll use less fuel as a result.
    Feb 2011
    Selby
    A12532F17W394 means it was made at the Aspern factory, on afternoon of May 5th 2003. It's a 5-speed wide ratio gearbox.
    So probably not off a facelift SRI at all...
    DURHAM
    Thanks very much . I thought it a bit odd for a 3yr old box to be in a 06 car !Dads just said his is vvt ! and his code is
    A02462F17W419 . This just gets better !
    Feb 2011
    Selby
    A02462F17W419
    That'll be Aspern factory, January 24th 2006 afternoon if I understand the codes correctly. Wide ratio too.
    DURHAM
    So a normal sri non vvt has a cr box,but a sri vvt has a wr ? Madness !
  1. Autosmart Tango Mix ratio ?
    By megsdad in forum General Chat
    Last Post: 4th January 2013, 23:01
  2. how can I measure boost, air mass and air-fue ratio
    By Caveman_nige in forum Vectra C / Signum Car Chat
    Last Post: 7th March 2011, 12:59
  3. Anybody know the gearbox ratio for the F40 box in the VXR ?
    By MrLOL in forum Vectra C / Signum Car Chat
    Last Post: 5th May 2009, 14:36
  4. c/ratio gearbox?
    By vectramad in forum Vectra C / Signum Car Chat
    Last Post: 30th August 2008, 07:31
  5. 2.2 design gear ratio ?
    By vocky in forum Engine & Drivetrain
    Last Post: 11th November 2007, 16:09
f17c gearbox
