Thread: 2.8 Missfire
    Regular Member Ziggy's Avatar
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    Default 2.8 Missfire
    Right then folks I have a misfire at WOT.
    I have read a few threads about this both here and on Saab forums and it would apear to be a spark plug issue.
    So whats the best route to take?
    Should I just fit new plugs?
    Is there an uprated plug?
    Can I get away with just regapping the plugs?
    Thank you
    Stephen
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    My advice would be new GM ones gapped correctly at 0.8...
    Front bank is easy to change, rear bank needs a little strip down to get too but only a 30 min job.
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    Just found a post from Spoons on VXRO
    "Engine misfires/engine juddering. This can either be due to spark plugs incorrectly gapped (0.8mm on mapped cars, and 0.7mm on high boost mapped cars). Or coilpacks failing. Coilpacks can be sourced for £50 each, so don’t pay the £250 each that Vauxhall quote. Other issues may relate to upgraded engine mapping from an independent tuner."
    As my car has been mapped I will start with the regap to .8mm. Or should I just upgrade to iridium spark plugs at the same time and get these gapped to 0.8mm?
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    double post
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    Quote Originally Posted by AntSSSS View Post
    Sorry just seen this post. Ill get some ordered.
    Middlesex
    Trim : SRI
    Mileage : 100k
    Quote Originally Posted by s_zigmond View Post
    I changed chrisvectra's on his VXR and his engine was as smooth as silk
    Defo worth changing the plugs before looking at coil packs. You often find that they are worn as people cant change them due to the rear bank.
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    Cheers mate. Will sort ASAP
    Full Member Big Sig's Avatar
    If your going to all the trouble of regapping them then change them at the same time.
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    New plugs were fitted, and it has improved, but I still have what appears to be a slight missfire at 3.5k rpm in 3rd. I have no error codes though and im no longer getting the cat warning.
    Anyone any ideas? If its a coil pack, how do I find out which one?
    Full Member gibbon7000's Avatar
    lincs
    Had this problem only the other week on my 2.8. If it is the coil pack it will give up soon and the EML will come on. Get the codes read. I was lucky it was cylinder no.2 which is front left. I'm sending you a PM
    My other car. 1972 1641cc slammed beetle. On the road finally!!
  1. Missfire!
    By R1-RAB in forum Engine & Drivetrain
    Last Post: 6th February 2010, 21:05
  2. missfire
    By alexgrfc in forum Engine & Drivetrain
    Last Post: 28th October 2009, 00:43
  3. missfire
    By robbie1944 in forum Engine & Drivetrain
    Last Post: 10th June 2009, 20:05
  4. missfire 2.2 dti sxi
    By woody in shetland in forum Vectra C / Signum Car Chat
    Last Post: 15th February 2009, 22:55
  5. 1.8 missfire.
    By 16vVec in forum Engine & Drivetrain
    Last Post: 19th September 2008, 20:02
