Results 1 to 10 of 18
Thread: Cdti silicon intercooler pipes fail ! No turbo?
    Regular Member Elahi_786's Avatar
    Oct 2010
    Bedford
    Exclamation Cdti silicon intercooler pipes fail ! No turbo?
    I had a a go at changing my intercooler pipes. Being in a rush I change the two R shaped hoses near the the AC Fill Tip. After having a blast and checking the pipes seemed fine. After another blast no Turbo sound but a pure whistle sound with no power then spanner light came on going up hill giving it some then it went off as I got up the hill.
    Have I ruined my turbo or is there more possible chance of loose hose or have loosened a hose whist wresting to put them on maybe have I damaged the intercooler? Whats the most likely thing? I want to have an idea as I will have the car seen too by regular diesel specialist.
    No power and chucking what i would call boost air through the exhaust.
    morecambe
    44 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Have the hoses split anywhere mate
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Have you tried the normal hoses again? My guess is the silicon ones may be collapsing under boost (inflating). Only a guess. I doubt it's a coincidence that it's doing it after you fitted these pipes.
    Oct 2010
    Bedford
    Thumbs down
    Due to it getting dark I had to rush the work. After driving 10 miles everything was fine into my 20th mile town driving all I am hearing is air / boost going through
    Oct 2010
    Bedford
    Cant see the hoses to be split anywhere. again used torch as it was dark
    Oct 2010
    Bedford
    Could the oil seals be gone or oil in the hoses therefore collapsing? Or Maybe turbo is stuck but there was no issues before?
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by Elahi_786 View Post
    Are you sure the hose hasn't just fallen off? To me it could be the hose that goes between the compressor and intercooler has came away or is leaking. This explains the noise but no boost (if I read you right). The spanner light will be coming on due to there being a boost leak as the leak is after the MAF in the intake system.
    Oct 2010
    Bedford
    Possibly would the spanner light explain where the problem is? I believe it could be the hose at the bottom left which then fits to the metal pipe as it was hard getting it on. Can I assume to say my turbo and intercooler have gone dead on me?
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Eh I wouldn't jump to conclusions yet. Check the obvious first. I think a pipe has came off. If something failed on the turbo - which is is purely mechanical, a spanner light would probably be the last of the tell tale signs I should imagine. Usually its a knackered engine/noise engine at best when vanes of the turbo shatter due to bearing failure.
    I think you have a split or loose hose.
    Oct 2010
    Bedford
    Right Thanks for that Gaz, ****** got me bothered all evening. Hope its nothing major or expensive.. Will Update tomorrow any other suggestions are welcome... Thanks Again Gaz !
  1. Silicon vac pipes
    By BigWilko in forum Y & Z30DT Specific
    Last Post: 24th October 2012, 06:02
  2. Cdti intercooler silicon hoses fitment help!!
    By Elahi_786 in forum Diesel Engine related
    Last Post: 27th March 2012, 06:54
  3. CDTI SILICONES PIPES Turbo Set
    By Elahi_786 in forum Styling
    Last Post: 25th February 2012, 13:50
  4. DPH Sport Silicon Pipes
    By cosmic in forum Vectra C / Signum Car Chat
    Last Post: 8th November 2011, 15:42
  5. Silicon pipes
    By MACVVT in forum Styling
    Last Post: 21st July 2011, 21:27
