Results 1 to 10 of 13
Thread: Single mass flywheel conversion
    New Member GrievousBee's Avatar
    Jan 2012
    Shoreham by Sea, UK
    Default Single mass flywheel conversion
    Hi peeps,
    Well my DMF has gone and done the dirty on me and is rattling like a good 'un.
    I really don't want to be spending out on something thats going to go again so I'm looking at a single mass flywheel conversion as the title says.
    Am I going to be getting more problems with this ?
    Am i just
    Car is a 2.0dti with 160k on the clock.
    Could the mileage be a problem.
    Thanks.
    Chris
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Their are reported problems some single conversions
    Mainly being extra vibration felt whilst driving.
    But this extra vibration CAN cause damage to gearbox.
    Very rare but also cases of snapped crankshafts from
    Single mass conversions an extra vibration damaging crank.
    IMO your best just fitting a DMF
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Double posy
    Kent
    Trim : SRI
    Engine : 1.9 CDTI 150
    be intresting to know how you get on with this as mine is going and thinking the same thing
    morecambe
    44 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    They re no good as critch says I welded my old one up in my old dti did the gear box in
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    I think the 2.0DTi uses the F23. The F23 is fitted with a single mass flywheel on the Vec b on petrol engines. It might be worth your while looking to see if the 2.0dti is fitted with a single mass and if indeed its a F23. However a conversion "kit" would have to be made and it may be the case thats its just a cheap just to stick with a DMF.
    Jun 2009
    Cheltenham
    QUOTE=paulvectrac;1768973]They re no good as critch says I welded my old one up in my old dti did the gear box in [/QUOTE]
    Welded it up and balanced it?
    Thought not.
    Engine : 1.9 CDTi
    Vauxhall dont fit the DMF for the fun of it.
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    Quote Originally Posted by lee gsi View Post
    millions of cars have run for millions of miles without one though!
    it makes me laugh that in this modern day, we need such things like dmf's and i laugh more when i hear ppl say that if you remove the dmf, it'l **** the gearbox in?
    what the hell's gone off with manufacturing then?.. are they making gearboxes weaker????
    we can put 300+ bhp though it and it will last years but remove the dmf and its toast?
    Engine : 1.9 CDTi
    Cars without DMF's have other parts in the engine and pulleys that dampen out harmonic vibrations.
    Cars with DMF's dont as the vibrations are dampened by the DMF.
    We get cars come in at work with noisey gearboxs and 9 times out of 10 they have had single flywheel conversions fitted. Granted they dont just die over night but they do do damage.
    At the end of the day if you dont want to keep a car forever then yes get one fitted and hope it doesn't kill the gearbox in the time you own it. However if you intend to keep it for a long time and do high mileage I wouldn't.
  1. Dual mass flywheel conversion.
    By andy-j in forum Vectra C / Signum Car Chat
    Last Post: 14th February 2013, 22:48
  2. Single Mass Flywheel conversion kit
    By dontsnatch in forum Vectra C / Signum Car Chat
    Last Post: 1st February 2013, 18:32
  3. Has anyone fitted a single mass flywheel to their 1.9 150 yet??
    By simmo3187 in forum Engine & Drivetrain
    Last Post: 31st May 2012, 16:28
  4. z20net single mass flywheel conversion
    By chesh1980 in forum Engine & Drivetrain
    Last Post: 13th March 2012, 17:23
  5. DMF Duel mass flywheel conversion kit?
    By pugs,signum in forum Engine & Drivetrain
    Last Post: 22nd May 2010, 19:51
vectra 2.0 dti flywheel conversion
vectra c 2.0 dti single mass conv
single mass conversion kits for zafira. 2.0dti
renault laguna single mass flywheel conversion
vectra c 2.0 dti single flywheel
vectra 2.0 dti single mass flywheel
vectra cdti single mass flywheel
changing dual mass flywheel to single mass on vectra c
f23 solid mass flywheel
vauxhall 1.9 cdti flywheel conversion
vauxhall vectra dual mass flywheel conversion
2004 vauxhall zafira convert dual mass to single mass flywheel
vauxhall vectra 2.0dti dmf conversion kits
