Thread: alarm going shortly after locking it up
    Regular Member Blurry120's Avatar
    Mar 2012
    Tameside
    8 Post(s)
    Trim : SRI with Design inside
    Engine : 1.8 16v ZXE18
    Mileage : 111,111
    Default alarm going shortly after locking it up
    1 week after ownin my veccy estate, and after washing it earlier the alarm goes off shortly after lockin it up, even switched keys to see if it made any difference, nope it didn`t, i`ve had to lock it up with the key for now, and i have noticed earlier before i washed it that there is a leak coming from some where and has gone over the plug for the alternator, wether its connected to the alarm goin off i`m not sure but its really annoying and i need to figure out how to sort it, any ideas anyone
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    check the window sensors in the boot area fella these problems point to the break sensors that run around the rear windows in the boot area
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Mar 2012
    Tameside
    8 Post(s)
    Mileage : 111,111
    how do i do that and what am i looking for, i have noticed two plugs that look as tho they are wired for the rear windows in the cubby holes where the rear boot lights are if that makes any sense, just need to know what i`m looking for
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    There should be a glass break strip running round the boot glass, a bit like the rear heater element, check that for and gaps, when you trace to the plug end, you should be able to short them together to fool the system is working properly, it it is indeed the glass break strip that had gone.
    Regular Member John Bishop's Avatar
    Oct 2010
    Search 'check safeguard' on the site. I had same problem and there is a How2 which shows you how 2 bypass it with a paperclip.
    Mar 2012
    Tameside
    8 Post(s)
    Mileage : 111,111
    Quote Originally Posted by bishbang View Post
    i`ve sorted it, i popped out and had a lok i`d rather have the alarm on, i didn`t use the paperclips tho, i used the metal that came off with the plugs, might have pulled too hard but, `safeguard` has gone and the alarm is back to its old self
    cheers guys for your help on this
    Oct 2010
    Nice one
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    Glad you got it sorted mate
  1. Alarm voluntarily sounding after approx 15 secs of door locking.
    By MattBrowning in forum Electrical & ICE (including SatNav)
    Last Post: 20th December 2012, 23:51
  2. Remote Locking/Alarm Problem (tried resyncing fob)
    By mattyc in forum Electrical & ICE (including SatNav)
    Last Post: 19th May 2011, 21:41
  3. Central Locking and Alarm Problems
    By Griff72 in forum Electrical & ICE (including SatNav)
    Last Post: 4th November 2010, 08:15
  4. Cheap Central Locking Alarm/Fob/Unit-WHERE CAN I BUY?
    By Vaux-Man-G in forum Electrical & ICE (including SatNav)
    Last Post: 3rd November 2009, 18:21
  5. Key fobs/alarm/ central locking playing up?
    By PeterVV in forum Electrical & ICE (including SatNav)
    Last Post: 11th April 2009, 22:31
