Thread: Engine rattle
    Regular Member wee-willy-winky's Avatar
    Feb 2012
    Witney
    Default Engine rattle
    Hi, I have bought a 2008 Vectra SRI and have noticed that when I turn it over there is a rattle like something is loose in the engine compartment, this has only happened a couple of times and of course I have checked it and all seems fine, the problem is not there all the time and since I have had it in the last 2 weeks has probably done it 3 times. Don't know if it has anything to do with it but when I bought it the gearbox was rebuilt due to it keep slipping out of first gear, but that is all fine now and feels great. Any advice would be very much appreciated.
    scottish region
    What engine ???
    Feb 2012
    Witney
    Petrol 2.2 Direct
    Regular Member skidmark1's Avatar
    Sep 2010
    cornwall
    Vehicle : 2.2 Direct
    Trim : SRI
    Engine : YH 2.2 petrol
    Mileage : 85000
    how many miles on the clock, mine had timing chain and balancer both done at 52k, that started with occasional rattle at start up.
    11 Post(s)
    My cam chain tensioner failed at 49,000 miles.
    http://www.vectra-c.com/forum/showthread.php?t=104735
    Not an uncommon problem with the 2.2
    http://www.z22se.co.uk/forum/threads...f-works.18355/
    http://www.justanswer.com/uk-car/4gi...-nnn-nnnn.html
    Field Remedy: 2366
    Subject: Engine Z22SE/Z22YH, tensioner timing chain - Rattling noise from timing chain
    Models: Vectra-B 2001...2003,Astra-G 2001...2004,Zafira 2001...2004,Speedster 2001...2004,VX220 2001...2004,Zafira-B 2005...2009,Astra-H 2007...2009,Vectra-C 2004...2009,Signum 2003...2009
    Engines: Z22SE,Z22SE,Z22SE,Z22SE,Z22SE,Z22YH,Z22YH,Z22YH,Z2 2YH
    Complaint: Rattling noise from timing chain, often together with elongated timing chain.
    Cause: Blocked timing chain tensioner.
    Production: A modified Z20NET tensioner will be introduced in production with MY 2009.
    Remedy:
    Note: For Z22SE engines please first take note of Quick Information 1532.
    In case of customer complaint exchange timing chain and install Z20NET timing chain tensioner part-no.: 12608580 / catalogue-no.: 48 07 839.
    FunctionalGroup: J - Engine
    Complaint Group: 05 - Excessive wear
    Trouble Code: None
    Feb 2012
    Witney
    great thanks for the reply, mine has done 65000 and am wondering if it would be covered on the warrantee, how much would it be costing to get the bits done? also would it be recommended to get it done asap or could i wait a little bit to see if it gets worse?
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    If its the chain its ASAP!!!! I believe Big Dave got 70% towards the costs from VX but that was with a Full VX service book I believe.
    11 Post(s)
    Yes Rushy, you're correct.
    All the info is in the link I posted earlier. What also went in my favour was mentioning the rattle while it was still under the 3 year Vx warranty, but typically it never did it when it was at the garage. Fortunately they made a note of it on their database.
    Feb 2012
    Witney
    Sweet, went to the vx dealer today and pointed out my disappointment at the situation and in under 5 mins they had agreed to pay the £792 for new chain and tensioner! also found out that when they rebuilt my gear box they forgot to re-charge my a/c so there is another 1.25 hr labour at £60.00 per hour plus the standard £90.00 diagnostic charge! Result.......... think they are now in a mahooooooooosive loss on my car now!
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Well done! good result
  1. VVT Engine Rattle.
    By VVT-i-MATT in forum Engine & Drivetrain
    Last Post: 27th November 2013, 18:24
  2. Engine cover rattle and engine cough
    By Hursty103 in forum Engine & Drivetrain
    Last Post: 15th May 2012, 12:22
  3. Replies: 35
    Last Post: 5th May 2012, 15:32
  4. engine rattle
    By paul wingnut in forum Engine & Drivetrain
    Last Post: 1st December 2009, 22:23
  5. Rattle on engine
    By andymcniven in forum Engine & Drivetrain
    Last Post: 7th January 2007, 11:49
