Thread: Steering column help please
    Regular Member TopRod's Avatar
    Liverpool, UK
    Default Steering column help please
    Ive had a problem with my steering column for about a year. About 70% of the time when I turn into corners I get a knock coming through the wheel. I've had the rack and everything checked in the steering and suspension assembaly but everything is fine. I've come to the conclusion that it's coming from the steering column its self. Is there anything that can wear out or break within the column that might give this symptom?
    I've heared that there is a spring somewhere in there that can snap and that is what it does feel like. You can actually hear the knock and it sounds like its coming from right behind the steering wheel.
    Any ideas? Cheers
    Aug 2010
    Derbyshire
    Check the lower column to steering rack pinch bolt, they can work loose. Mine had and I just nipped it up half a turn. You can gain access to it down behind the engine.
    If you had your steering checked though they may have looked at that.
    Mick
    East Ayrshire
    Trim : SRI XP1
    As above, torque it up to 22nm(im sure thats what it is). I usually give it another wee 1/4 turn after that aswell. Done it to mine a year ago, havent had any hassle since
    Liverpool, UK
    Thanks, do you have to use a ramp to access this? Where is the upper pinch bolt located? Can that do the same? Have you got any pictures at all?
    Cheers.
    East Ayrshire
    Trim : SRI XP1
    Sorry, just told you how to do a corsa lol. Engine compartment, back left hand side where the colum comes through the bulkhead. You'll see the steering knuckle, looks similar to this http://www.ebay.co.uk/itm/Vauxhall-V...item4ab5b613bd
    Cant remember the size of the bolt, takes a couple of minutes
    Last edited by stevie16v; 26th March 2012 at 21:06. Reason: It's a vectra not a corsa
    Liverpool, UK
    Cheers I'll have a go, do you need a ramp to do this or can it be done without?
    East Ayrshire
    Trim : SRI XP1
    It's all done from above. Just pop the bonnet and look down towards the rack just in front of the drivers position
    Liverpool, UK
    Thanks mate I'll give it a go and let you know either way.
    Liverpool, UK
    Quote Originally Posted by MickAP View Post
    Mick
    This seems to have been the problem mate!! I've done what you suggested and the knocks are gone and thats been annoying me for the best part of a year!! Although it seemed to be the upper pinch bolt under the steering wheel that was loose. I gave it about a quarter of a turn, the lower one didn't seem lose. Thanks for the tip!!
    TopRod.
    Aug 2010
    Derbyshire
    Quote Originally Posted by TopRod View Post
    TopRod.
    Yep it's an easy one, mine was doing the same until I sussed it with a little help from the forum.
    Mick
  1. Steering column movement.
    By TopRod in forum Vectra C / Signum Troubleshooting
    Last Post: 30th June 2011, 13:14
  2. steering column shroud
    By chaddopete in forum Electrical & ICE (including SatNav)
    Last Post: 23rd January 2010, 17:13
  3. steering column problem
    By veiluoks in forum Engine & Drivetrain
    Last Post: 4th October 2009, 16:19
  4. Steering column adjustment ???
    By C4REK in forum Vectra C / Signum Car Chat
    Last Post: 8th February 2008, 00:44
  5. steering column
    By robjones in forum Vectra C / Signum Car Chat
    Last Post: 28th January 2008, 18:32
vectra c steering knuckle
