Results 1 to 10 of 15
Thread: brown/grey-yellow wires under the ashtray
    Regular Member sig63's Avatar
    Belgium
    Vehicle : Opel Insignia
    Trim : Cosmo
    Engine : 2.0 CDTI
    Year : 2011
    Question brown/grey-yellow wires under the ashtray
    Does anyone know what the brown/grey-yellow wires under the ashtray are used for ?
    see pic (I borrowed it from someone but cannot find the thread anymore...)
    It seems that it works together with the dashboard lights.
    Is it Ok if I use this for an ashtray-light?
    Anyhow, it's the only wiring I can reach 'cause I cannot remove the ashtray base
    And third: do I have to take care for something if I tape one or two LED-dots somewhere on the ashtray base?
    Regular Member david-bell's Avatar
    eastlothian scotland
    Vehicle : vectra vxr
    Trim : vxr
    Engine : 2.8 v6 turbo
    Mileage : 31000
    christ dont tell me that vx have done away with an ashtray light on the newer models aswell as my 2004 vec has a light built in
    Belgium
    Trim : Cosmo
    Engine : 2.0 CDTI
    Year : 2011
    It is an Opel MY 06 without 'smokers pack', which means I have an ashtray (funny but luckily ) and a power socket, but no lighter, no ashtray light and no illuminated ring around the lighter
    Trim : vxr
    Mileage : 31000
    Quote Originally Posted by sig63 View Post
    ah that it explains it then not sure mate about the wires
    VOTING UKIP IN AVELEY
    20 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    going on from this,i,m sure my ashtray lifts out and there is a connector hiding underneath,any ideas what this is ?/ i,m probibly guessing that this has been gone over b4.
    Belgium
    Trim : Cosmo
    Engine : 2.0 CDTI
    Year : 2011
    Quote Originally Posted by soulman View Post
    That is the Tech2 connector port
    Really nobody who knows the use of the white plug with the brown and grey/yellow wires
    Melbourne, Australia
    Mine uses a connector with this colouring for the ashtray lamp, so should be OK.
    Belgium
    Trim : Cosmo
    Engine : 2.0 CDTI
    Year : 2011
    It may be the illumination feed to the ashtray light and also the gearshift lighting on the automatics...i'll have a look later on...
    It's definitely the wiring to go into the ashtray light. I'm guessing yours hasn't got the light in the ashtray then?
  1. Facelift Xenon Headlight wiring n/s yellow & white wires
    By Simon_Fuller in forum The 'Off Topic' room
    Last Post: 8th December 2012, 17:12
  2. Illumination Wires - Yellow/Grey...
    By Leemarksmith in forum Electrical & ICE (including SatNav)
    Last Post: 16th June 2010, 01:44
  3. grey plug yellow plug?
    By paul_sri150 in forum Electrical & ICE (including SatNav)
    Last Post: 23rd May 2010, 14:35
  4. Rear Cig Lighter... Grey/Yellow wire...
    Last Post: 6th March 2010, 01:44
  5. found this Yellow vectra c? did they make a yellow one?
    By Craig1985 in forum Vectra C / Signum Car Chat
    Last Post: 16th February 2010, 02:50
wiring under ashtray vectra c
what is socket under ashtray
vauxhall yellow grey and brown wire
