Thread: Check parking light?
    Regular Member krazylegz's Avatar
    South Shields
    Default Check parking light?
    What's the deal with this?
    Keep getting a error up saying " check front parking light" on the GID.
    This only comes up when my lights are turned off, if I turn on my lights they all work and the message doesn't come up?
    Any ideas anyone?
    Engine : 1.9 CDTi
    It will put up the error a little while before the bulb blows as the bulb will change resistance.
    Give it a few weeks and it will go faulty.
    Feb 2011
    Selby
    The bulb testing system works by passing a very small current through the bulbs - not enough to light them, but enough to measure the voltage drop so it can determine if the resistance is outside the acceptable range. So a bulb doesn't actually have to be completely failed to register as in need of replacement - it's probably that it's only got a few hours of life left.
    Alternatively, you might just have a dirty connection, which is making it think the bulb is about to fail. So I'd take both sidelight bulbs out, give their contacts a clean and refit them.
    South Shields
    Cheers lads I'll get 2 from work and change them and see if the connections are ok.
  1. Parking light, check left
    By SlowCoach in forum Electrical & ICE (including SatNav)
    Last Post: 21st October 2012, 09:00
  2. Check right parking light
    By ian mc in forum Electrical & ICE (including SatNav)
    Last Post: 27th July 2009, 21:31
  3. Parking light/side light
    By mc_orion in forum Vectra C / Signum Car Chat
    Last Post: 30th January 2009, 11:14
  4. Parking light check bulb light on and wont go off
    By rollercoaster63 in forum Vectra C / Signum Car Chat
    Last Post: 16th November 2008, 12:03
  5. Check right parking light.....
    By ROB WOODHOUSE in forum Electrical & ICE (including SatNav)
    Last Post: 16th November 2006, 23:39
parking light check right opel
