Results 1 to 10 of 19
Thread: Sump plug rounded off - Help
    Regular Member Barlow's Avatar
    Jan 2012
    Chester
    Vehicle : Nissan 350Z GT
    Engine : 3.5 V6
    Year : 06
    Mileage : 50,000
    Default Sump plug rounded off - Help
    Went to do the oil change yesterday and some r-tard has rounded off the sump plug. I mole gripped and hammered the hell out of it for over an hour and it wouldn't budge.
    Before I take it to a garage for a £50 bill, has anyone got any suggestions?
    I've ordered another plug and washer.
    1.9 120
    Regular Member Keif's Avatar
    In the Garage
    If you get a small centre punch and use that to tap the sump plug round do undo it. The shock will normally release it.
    Regular Member haye2412's Avatar
    Aug 2009
    portland
    I had this prob I drove on a smaller socket and it came of all so try water pipe stilsons this may all so work good luck with it .
    May 2006
    scotland
    Quote Originally Posted by Barlow View Post
    1.9 120
    Mole grips would have been my suggestion but you have tried that. I do not know how hard the metal of the plug is but is there any chance you can hammer on an imperial hex plug to try and force the sump plug to its shape, enough to get some purchase. Watch it does not slip and you end up in A&E though.
    Full Member coldo's Avatar
    Scotland
    Quote Originally Posted by wickedwillie View Post
    +1
    Jan 2012
    Chester
    Engine : 3.5 V6
    Year : 06
    Mileage : 50,000
    Quote Originally Posted by Keif View Post
    Tried that too mate.
    Quote Originally Posted by haye2412 View Post
    Tried it. Hammered a 11mm on and it just slipped off.
    Tried that too Willie. I've got a ton of Imperial stuff from when I had a Landy.
    Dec 2011
    Seaham
    You can get some reverse cut stud extractors, the more you turn to loosen the bolt, the more they bite into the head.
    Bit like the ones used to remove locking wheel nuts!
    Jun 2011
    Herts
    I just don't know why these idiots do the sump plug up like it is meant to hold the car together!!!!!!! Only a wee nip needed to squash the washer........
    have you tried heating her up a bit and putting some wd40 (type stuff) around it???
    I've heard the irwin bolt/nut extractors are the bees knees though so as a last resort they'll get you out of the stook
    Jan 2010
    Trim : 1.9 cdti
    Engine : 120
    Year : 06
    Irwin bolts/nuts extractor is the way to go. Used them at the weekend and the sump plug came off easily. You just hammer on the 13mm till you get a grip, attach a bar to the rachet and off you go. You might have to use the 11mm if the bolt is well round though.
    http://www.ebay.co.uk/itm/Irwin-Bolt...item2319401800
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    as the others have said bud IRWIN EXTRACTORS are the way to go ive a set of these and they worked a treat fella on my sump plug
  1. Spark Plug & Sump Plug Torque setting - Z18XE Engine
    By wafoo in forum Engine & Drivetrain
    Last Post: 4th June 2012, 21:15
  2. Rounded off sump plug... any ideas?
    By BigWilko in forum The 'Off Topic' room
    Last Post: 20th July 2010, 22:10
  3. sump plug rounded off/wrecked
    By bigben in forum Engine & Drivetrain
    Last Post: 30th April 2009, 21:46
  4. getting the sump plug out ????
    By Nickzx6r in forum Engine & Drivetrain
    Last Post: 6th October 2007, 07:55
  5. rounded sump plug
    By baz2003uk in forum Vectra C / Signum Car Chat
    Last Post: 11th June 2007, 20:43
vectra c using hex sump plug www.vectra-c.com
how to get a rounded sump plug out of a vauxhall vectra
