At low speeds generally when moving off i get what sounds like creaking from the back end but cant seem to locate the fault, any suggestions?
Boot lid
Look down where the boot-lid locks on to. Remove the plastic trim in the boot. There's two bolts that loosen to move the metal bit down (not sure of the proper name, but it's what the lid locks on to)! Mine moved down about 1-2 mm, and that was enough tto stop it creaking
had the same problem but with all the adjusting in the world i could not make it stop!
resulted to black electrial tape wrapped round the latch a few times
sorted
check rear suspension arm top of the sub frame one of the bushes lower arm
