Results 1 to 3 of 3
Thread: About to lower - questions help?
    Regular Member vads's Avatar
    Mar 2012
    Fife
    Default About to lower - questions help?
    Hi all,
    I'm preparing to have my 1.8 lowered and have been doing a lot of reading / learning here, but i have a few questions:
    I have the common knocking noises so whilst its being lowered i'd be aswell to replace the drop links and arbs. Is there anything else that i should get replaced whilst its being lowered?
    I'll be going for the eibach 30mm drop springs and uprated droplinks.
    Also how much should i expect to pay for parts / fitting?
    any recommended garages or members to carry out the work in Fife area?
    thanks!
    Jun 2011
    Herts
    do a search- loads of info if you want to look.
    Regular Member coldo's Avatar
    Scotland
    I did mine recently with the help of a mate... A dead easy thing to do yourself if you have the tools. A garage will charge arround £100 for springs and top mount bushes. The ARB bushes will be sliglty more...
    If your going to swap bits out I would chaneg the following...
    Springs (obviously)
    Top mount bushes
    Drop links (dont get cheap ebay ones.. Get either GM ones or Sab ones)
    ARM Bushes
    Make sure you swap the plastic covers on the bottom of the springs also (easy to miss)....
  1. I Need To Go Lower!
    By Lean6 in forum Handling & Braking
    Last Post: 25th June 2012, 07:54
  2. Can Someone Lower my car please?
    By HuddyHudson in forum Photoshop section
    Last Post: 4th December 2010, 21:16
  3. Replies: 21
    Last Post: 30th November 2009, 22:21
  4. Lower. Y Or N ???
    By Lee.. in forum Vectra C / Signum Car Chat
    Last Post: 16th March 2008, 20:11
