Thread: Loss of turbo whilst driving
    Solihull
    Vehicle : safira
    Trim : Se
    Engine : 120
    confused Loss of turbo whilst driving
    The Turbo drops out when Im slightly pulling up hill or easing off...
    Checked the HP lines from the turbo through the intercooler, no leaks
    All I get is 3000 rpm and really flat acceleration.
    Power off and re-start its all ok for a while.
    Cdti 150 - 06 estate
    South Central England
    9 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    No fault codes??
    Solihull
    Vehicle : safira
    Trim : Se
    Engine : 120
    not that I know?
    if i keep going eventually it picks up again and its fine for a while
    9 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Very strange, even more so that the ECU is not logging a fault. Things that might have cause that which should log a fault are:
    1) EGR as always
    2) Vacuum control line to turbo actuator leaking
    3) A remap or tuning box issue
    Solihull
    Vehicle : safira
    Trim : Se
    Engine : 120
    Been and bought a new MAF, but this now needs setting up?!?
    Will ask for help again .....
    Sep 2011
    Caerphilly
    Vehicle : saab 93 tid(150)
    Trim : sport
    Engine : 1.9 z19dth
    Mileage : 63000
    Quote Originally Posted by digitalinkjetman View Post
    Quite possible as you have an estate that the dpf is 70%+ saturated and putting strain on the engine due to the blockage or even limp mode, would have thought eml would be on mind but you never know
    Solihull
    Vehicle : safira
    Trim : Se
    Engine : 120
    Yep it was a blocked DPF!
    Dismantled it now and it runs like never before!
    Thanks for all the pointers
    Regular Member SarahP's Avatar
    Nov 2011
    Buckinghamshire
    what do you mean by dismantled?
    9 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    MAFs don'tt need setting up, just putting in :/
    Solihull
    Vehicle : safira
    Trim : Se
    Engine : 120
    Quote Originally Posted by SarahP View Post
    It had a 12mm drill put through it four times!
    Now allows the exhaust to flow....
  1. on the phone whilst driving
    By hippo in forum General Chat
    Last Post: 18th February 2012, 11:04
  2. Sudden changes in MPG whilst driving
    By cyb3rthug in forum Vectra C / Signum Troubleshooting
    Last Post: 1st October 2011, 11:17
  3. hesitation whilst driving
    By RichyA in forum Vectra C / Signum Car Chat
    Last Post: 11th October 2010, 07:59
  4. spanner light whilst driving
    By porthy-t in forum Engine & Drivetrain
    Last Post: 8th November 2009, 17:27
  5. Mobile Phone usage whilst Driving !
    By Vaux-Man-G in forum The 'Off Topic' room
    Last Post: 25th June 2008, 23:05
