Page 1 of 4 123 ... LastLast
Results 1 to 10 of 35
Thread: vectra 2.0 turbo z20net lumpy idleing (can anybody come help )
    Regular Member matrix1979's Avatar
    Aug 2007
    NORFOLK
    Default vectra 2.0 turbo z20net lumpy idleing (can anybody come help )
    hi people im still having problems with my 07 plate veccy 2.0 turbo z20net engine running lumpy as hell on idle along with strong exhaust smell which im sure its running rich due to the back boxes being all sooted up and my mpg droped . I have done many of things changed the maf sensor , air filter . air box mod, checked the turbo seals were nt leaking, cts sensor, flexi looks fine , did nottice 2 screws on the inlet manifold were loose but all tightened up now , has no error codes , the lumpy idle get worse when the engine gets hot , Im just coming to the end of my teather with it and want to just get to the bottom of it if anybody could come have a look it i would be very greatfull i would pay you of course i live in kings lynn in norfolk or im willing to travel to you if your not to far from me ,
    Regular Member Kev_A's Avatar
    Gateshead, Tyne and wear
    Engine : Z20NET
    Have you checked your plugs, coil packs and fuel filter bud?
    Aug 2007
    NORFOLK
    plugs have recently been changed 1 k ago coil packs are fine been tested , as for fuel filter will change this coming week . u know where this is situated exactly ?
    Engine : Z20NET
    I beleive it's under the car O/S/R, I have mine to do too
    morecambe
    33 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    What about the maf
    Aug 2007
    NORFOLK
    changed that paul ;( still no joy
    Aug 2007
    NORFOLK
    might give courtneys at north walsham a call tommoz see what they say ;S
    Mar 2012
    alton
    Sounds like its the good old EGR valve clogged! Have you done that ? You can clean them but I found a new one will last longer with out cleaning.
    Jan 2006
    Dalriada
    EGR on a petrol turbo...?
    Full Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    When mine was doing this I changed the fuel filter and it sorted it.
  1. Replies: 19
    Last Post: 6th September 2014, 13:54
  2. lumpy tickover z20net
    By tomo41 in forum Engine & Drivetrain
    Last Post: 21st June 2012, 10:30
  3. lumpy idle 2.0 turbo
    By tecg in forum Engine & Drivetrain
    Last Post: 14th December 2011, 21:21
  4. z20net lumpy idle running rough
    Last Post: 7th July 2011, 23:06
vectra 2.0turbo egr
