Results 1 to 10 of 15
Thread: 1.9 150 creaking noise whilst moving off
    Regular Member amand's Avatar
    Feb 2011
    west London
    Default 1.9 150 creaking noise whilst moving off
    once i hit biting point i hear a creaking noise. Anyone else been through this?
    Nov 2010
    Warrington
    Does it sound like the ABS self test? If it does, it's probably some wear in the CV joint.
    Regular Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    any update on this one?
    Feb 2011
    west London
    still got the noise, looking around people have said it could be radiator mounts, but i don't know where they are located.
    Jun 2009
    South Coast
    i have it also and its getting worse.. Its bugging the hell out of me.. I have ordered some powerflex ARBs although mine were all replaced 3 years ago with GM bushes.. Also in the last three years all shocks and springs have been replaced/uprated, both track rod ends, both wishbones, both outer CV joints, all calipers and carriers etc, droplinks are new and the uprated versions. Nothing left to replace......
    Jan 2012
    stoke on trent
    I used to have a "creaking" coming from the front end when going over speed bumps, replaced the roll bar bushes and all ok now
    Jun 2009
    South Coast
    mine is fine over bumps and any other time, not sure about the OP..
    Mine is exactly has he describes though, just as you reach the clutch bite point and slowly pull forward it creaks then from somewhere in the front end, as you move forward after that no more creaks until you stop and then have pull away again...
    I went out this evening and sprayed the cv boots (just because its a moving rubber part) and existing ARBs with a silcone spray and still the same..
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 132000
    Quote Originally Posted by amand View Post
    this may help
    http://www.vectra-c.com/forum/showth...+mounts&page=2
    http://www.vectra-c.com/forum/showth...adiator+mounts
    Jun 2009
    South Coast
    well theres nothing to be lost in spraying some more rubber components.. will do those when i get from leeds tomorrow..
    May 2011
    Leeds
    This definatly sounds like the radiator mounts. if you spray with WD40 this should sort out the problem for a short time at least
  1. 1.8vvti repetative noise whilst driving..opinions please
    By Ademusic in forum Engine & Drivetrain
    Last Post: 7th December 2011, 22:02
  2. Whooshing noise above 2000rpm whilst driving in hot weather
    By marky2027 in forum Engine & Drivetrain
    Last Post: 26th August 2009, 22:02
  3. creaking noise
    By signumboy in forum Suspension, Wheels & Brakes
    Last Post: 14th March 2008, 22:44
  4. Noise from rear whilst in reverse
    By zipfree in forum Suspension, Wheels & Brakes
    Last Post: 27th November 2007, 08:24
  5. creaking noise
    By johnnyhg in forum Vectra C / Signum Car Chat
    Last Post: 30th June 2006, 19:52
