Thread: Swirl Flaps & Fuel Pump 2.2 Direct
    Dec 2010
    East Lothian
    Default Swirl Flaps & Fuel Pump 2.2 Direct
    Hi!
    The emissions light came on in our 06 2.2 Direct last week. My sons friend put the car on their code reader but it showed no faults. The car was starting fine and would rev all the way up no problem.
    The problems started when the car was driven - Instantly the emissions light came on again and the car went into limp mode. it seemed the car was struggling under load.
    The garage took the car in on Monday and said they had a fault code which made them think it was the Swirl Flaps.
    Now the swirl flaps have been replaced the garage have called and said the Fuel pump has gone too.
    Is it likely that both had gone at once or are the garage just saying that because they have misdiagnosed the problem originally?
    Many thanks!
    Lorna
    Jun 2009
    Middlesex
    Having similar problems with my 2.2 direct (04 reg).Got engine management light on (car & spanner light).Fault codes P1191 & P1112.
    Looks like a fuel pressure regulator but not certain.Had H.P Fuel Pump & Regulator replaced less than 3 years ago at my expense.
    (see my thread today)
    Dec 2010
    East Lothian
    The codes we had were P1112 & P0302
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Get some carb cleaner through it. It may help with the flap issue, it has in the past when they start to clog up.
    Regular Member simplesi's Avatar
    Aug 2009
    probably off taking photos
    Vehicle : 1.9 cdti 150
    Trim : elite
    Quote Originally Posted by Bobster691 View Post
    same when mines went swirlls and hpfp got mine for free though lol
  1. does 2.2 direct fuel pump
    By coolj in forum Vectra C / Signum Car Chat
    Last Post: 29th August 2012, 14:47
  2. 2.2 direct fuel pump and fuel pressure regulator
    By w111y in forum Engine & Drivetrain
    Last Post: 11th July 2012, 22:12
  3. 2.2i direct fuel pump
    By gordy07 in forum Engine & Drivetrain
    Last Post: 4th October 2011, 19:39
  4. 2.2 Direct Fuel Pump
    By Paul_NI in forum Engine & Drivetrain
    Last Post: 8th August 2011, 12:22
  5. 2.2 direct fuel pump
    By edwardabud86 in forum Vectra C / Signum Car Chat
    Last Post: 6th February 2010, 21:59
