Thread: bad start
    Regular Member ANDY GSI's Avatar
    dumbarton,scotland
    Unhappy bad start
    hi all, had this problem since i bought the car 2 months ago and thought i new what was causing it but still not got to the cause yet? first thing in the morning and when its been sitting for hours after work the car takes ages to start but any other time it starts first turn?? so far i have changed the glow plugs (from vauxhall) the battery (from vauxhall) and a vacum pipe that was split. the car is a signum design 1.9 cdti 8v 120bhp 2006 with 67000m on. need some help thanks!
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Coolant temp sender maybe?
    dumbarton,scotland
    how would this affect the starting of the car? cheers
    Mar 2012
    alton
    coolant temp sender tells the ecu how long to heat the plugs, it can make the ecu think the engine is hot when infact its cold, r you getting a diesely white smoke on start up?
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Try unplugging the coolant temp sender in the morning before you start it. If it starts quicker, then that's your problem Plug it back in once started
    dumbarton,scotland
    Cheers mate I will try that in the morning and c how it goes
    East Kilbride
    Engine : 3.2 v6
    Mileage : 110,000
    Have you checked your fuel lines for leaks, this used to be a sure sign of air in the system. It basically caused the engine to self bleed, not too sure if it applies to modern engines though.
    3.2 v6 Signum and loving it
    dumbarton,scotland
    Quote Originally Posted by Johnsdutton View Post
    I think it would be hard to start all the time if this was the problem but i will check them out, cheers
    East Kilbride
    Engine : 3.2 v6
    Mileage : 110,000
    Quote Originally Posted by ANDY GSI View Post
    Not strictly true, as being left for a long period of time could possibly cause fuel to leak and air be drawn into the system.
    dumbarton,scotland
    Quote Originally Posted by jock View Post
    No there is no smoke on start up will try to unplug and c what happens
  1. car won't start :-(
    By michael_linford in forum Electrical & ICE (including SatNav)
    Last Post: 29th December 2012, 19:31
  2. Were do i start
    By MCCABE in forum Engine & Drivetrain
    Last Post: 6th March 2011, 21:34
  3. 2.2 sri non start
    By Diesel Dude in forum Engine & Drivetrain
    Last Post: 13th February 2011, 00:44
  4. Cars dead. Won't start. Fan runs when it would start.
    By baz_rochdale in forum Electrical & ICE (including SatNav)
    Last Post: 14th September 2010, 22:34
  5. 2.2 DTI will not start!!!!
    By Mark121 in forum Troubleshooting
    Last Post: 7th September 2010, 13:02
