Thread: Air con keeps charge but not cold
    Feb 2012
    Peterborough
    Default Air con keeps charge but not cold
    Hi
    Vectra c 1.9cdti (120) air co is charged and keeps charge but im getting no cold air. ican hear the compressor cutting in and you can hear it in the tone of the engine. but there is no cold air.
    is there any diagnoses i can do at home before i get a big bill.
    also where is the filter?
    thanks in advance
    Marcus
    Are you sure the heater isn't still on?
    Feb 2012
    Peterborough
    Definitely goes from hot to ambient went I turn temp dial
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Is the air temp mixer flap moving properly?
    Mar 2012
    eaglesham,scotland
    try a pollen filter i had a astra h with same prob it did make it it cooler and they only cost 10 or 20 quid
    Feb 2012
    Peterborough
    Is the pollen filter located under the flap near the wiper
    Feb 2012
    Peterborough
    VIP-Member
    Dec 2010
    London
    Engine : Z18XER
    yep on passenger side
    Full Member Robsey's Avatar
    North East Cheshire
    14 Post(s)
    Trim : Energy
    Mileage : 131,000
    I read that you say that it charges and keeps charge - do you mean the pressure within the system?
    The condensor on the Vectra-C is a known weak point, that gets shot-blasted and eventually becomes holed by stones and grit being thrown up at the front of the car.
    Mine has recently lost it's refridgerant, but you can still hear the engine note change when you turn the air-con on. - so the compressor kicking in.
    A new condensor and receiver dryer are approx £90 to £150 plus postage on ebay, and then it would need to be fitted, all moisture vacuum out of the system, and the the whole thing regassed,
    Stupid money at the dealers.. one of the seal washers is £15 on it's own from Vx.
    A generic equivalent is less than a quid from an air-con supplier.
    Not asking for help, I am just asking the OP if he is sure that he has not lost refridgerant.
    I used Vaux-Com to tell me that my pressure was approx 105 kPa (just above atmospheric pressure). - should be a lot more than 320 at idle, rising by 500 when the air con is switched on.
    Feb 2012
    Peterborough
    Thanks for response,
    All I did was get a pressure of 25 psi on the low pressure side, ran the air con for 10 minutes ( not cold but heard a clunk ) and still got 25 psi whilst running. Not sure if the pressure is correct but I believe at approx 18 deg c the pressure should be between 25 and 30 psi.
  1. random cold knock/tick sound when cold - 1.9 cdti
    Last Post: 18th January 2013, 18:59
  2. What would a dealer charge....
    By golfpro in forum Vectra C / Signum Car Chat
    Last Post: 13th January 2013, 21:35
  3. Air con diy re charge
    By winnie2457 in forum Engine & Drivetrain
    Last Post: 24th June 2010, 22:01
  4. How do you think VX will charge for...
    By n_hudson in forum Vectra C / Signum Car Chat
    Last Post: 15th January 2009, 21:53
  5. VX Charge.
    By LAV6Y in forum Vectra C / Signum Car Chat
    Last Post: 14th March 2008, 16:13
