Thread: 2.0 turbo warm start problem
    Regular Member pipamish's Avatar
    wolverhampton
    Trim : Sri
    Engine : 2.0 turbo
    Default 2.0 turbo warm start problem
    A question for all you 2.0 turbo owners.
    After I have driven the car and it's warm upon restarting it feels like it doesn't start up properly the revs are low and at the back of the car it sounds like the exhaust is shaking something seems strange anyway. I don't normally drive the car long distances and not for long periods either anyone got any ideas.
    Oh it has 48000 on the clock
    Regular Member beat275's Avatar
    Aug 2011
    Newcastle West Denton
    Vehicle : Hatch
    Trim : SRI
    Engine : 2.0T
    Mileage : 90000
    I also have the same problem. Does yours sound like it gunna stall for a few seconds
    wolverhampton
    Trim : Sri
    Engine : 2.0 turbo
    Quote Originally Posted by beat275 View Post
    I would not say stall but revs are Low all I do is blip the throttle and it's back to normal
    Aug 2011
    Vehicle : Hatch
    Trim : SRI
    Engine : 2.0T
    Mileage : 90000
    Yeah exactly the same as me and the exhaust sounds like its got a stone in it. Hope someone can help with this
    Jun 2009
    South Coast
    Vehicle : Vectra, Signum & Insignia
    Engine : Z18XE,Z19DTH,Z20NET,
    when did you last change your fuel filter? Have you cleaned out the throttle body, was it manky or clean? Have you cleaned the MAF and MAP sensors? On startup the lambdas are not in the loop but I would clean them anyway, carefully though? Have you checked the condition of your spark plugs to see if what colour they are?
    The wifes vec show car is currently being stripped for parts before i scrap it, keep an eye on the sales section.. https://www.vectra-c.com/forum/garage_vehicle.php?do=view_vehicle&id=709
    wolverhampton
    Trim : Sri
    Engine : 2.0 turbo
    Where will I find all these parts nige I know where the throttle body is mind
    Jun 2009
    South Coast
    Fuel filter is under the car, roughly under the rear drivers side passenger..
    MAF is the in the air intake pipe between the airbox and the turbo, just blow through it or use an evaporating cleaner like brake cleaner spray, but sparingly..
    MAP sensor is in the boost pipe coming up from the intercooler, the sensor is in the top of the plastic section just before the rubber,silicone pipe joins and goes to your throttle body.
    Lambda 1 is in the downpipe on the first bend before the cat.
    Lambda 2 is in the exhaust mid section after the flexi..
    Spark plugs, well i hope you know where they are mate.... please say you do...
    Vinegar is pretty good for cleaning lambdas if you ever need to clean them..
    wolverhampton
    Trim : Sri
    Engine : 2.0 turbo
    Quote Originally Posted by Caveman_nige View Post
    Yes lol i know where the spark plugs are i will get it around my mates and ill change fuel filter and spark plugs will also give the map and maf sensor a clean see if that makes a difference
  1. Vectra wont start when warm!
    By haye5 in forum Engine & Drivetrain
    Last Post: 14th November 2017, 17:32
  2. Must push Accelerator when car is warm to start. Why??
    By Tank988 in forum Engine & Drivetrain
    Last Post: 8th November 2012, 00:33
  3. signum dti hard to start when warm
    By deano1 in forum Engine & Drivetrain
    Last Post: 17th September 2012, 07:30
  4. Vectra 2.0 DTi difficult to start when warm
    By C470 in forum Engine & Drivetrain
    Last Post: 11th July 2012, 16:35
  5. vectra start up/turbo problem
    By fizler316 in forum Vectra C / Signum Car Chat
    Last Post: 28th February 2011, 02:41
signum 2.0 t problems
vectra 2.0t struggling to start
vauxhall vectra c 2.0 turbo turbo cleaning
vectra c 2.0 turbo trouble starting
